Alternator seized... or something...
Electrical and Ignition
  1. 68_Valiant_Wilson
    68_Valiant_Wilson Active Member
    27
    1
    Jul 31, 2017
    Clinton
    Local Time:
    3:45 PM
    Ok well here goes a pretty long story. So I've got a 68 Valiant with a slant six in it. One day I left the lights on by accident. I then had a slight feeling that I left the lights on that evening but I brushed it off. Anyways, the next morning the battery is completely dead and lucky I didn't really have anywhere to go so I just took the battery inside and trickle charged it because my dad needed to go to work the next morning and wasn't going to be able to take the car he usually did. It was about 11:00 at night and he wanted me to go reconnect the battery so I did. I couldn't see well enough and it didn't help that both the battery cables are black. Long story short I hooked up the battery backwards and burnt out the fusable link. Me and my dad have already replaced the fusable link with a automatic reset circuit breaker and we replaced any other burnt out wire. I thought were have alternator problems before I hooked up the battery backwards so I took the alternator to get tested and sure enough it was bad. No big deal so we just got a new alternator. The only big difference between the two alternators was that the first one was a 2 groove pulley and the new one was a 1 grove pulley. I fiddled with the new alternator before we put it on and it seemed to work fine like it turned like it was supposed to. Then we installed it.(NOTE:we put in the alternator a few days before we replaced the wiring and circuit breaker). Once we replace the wiring,circuit breaker, and got a new battery we were ready to start it. Went to start it and it made a real loud squeaking noise but you could tell it tried to turn over so it wasn't the starter. I watched it while my dad started it and saw that the alternator was moving at all! THE BRAND SPANKIN' NEW ONE! We took the belt off and just tried spinning it with our hand and it wouldn't budge. Is there anything you can do to fix this or am I better off just getting a new alternator?
  2. 4spdragtop
    4spdragtop CONGRATS NORTH AMERICA! FABO Gold Member
    32,427
    13532
    Aug 28, 2009
    Wasting time here
    Local Time:
    2:45 PM
    Thats the new alternator? Why dont you return it under warranty.
    And whilenyer at it get some red paint/tape/nail polish
  3. 68_Valiant_Wilson
    27
    1
    Jul 31, 2017
    Clinton
    Local Time:
    3:45 PM
    That's probably what I'll end up doing. But what would make an alternator lockup like that? Thanks!
  4. 67Dart273
    67Dart273 FABO Gold Member FABO Gold Member
    51,434
    20387
    Oct 14, 2010
    Idaho
    Local Time:
    12:45 PM
    It's called cheap crap rebuilts. They have been this way in some measure since I was young THE FIRST DANGEROUS DEFECTIVE REBUILT alternator I ran into was about 1978
    I worked parts then. Some guy had bought a replacement (isolated field) alternator for his '70's pickup. Came back in a day later and said "it's overcharging."
    I knew immediately what was wrong..........one of the two field terminals WAS GROUNDED. This means he'd had a 50-50 chance "and won." He had accidently hooked the blue IGN wire to the ungrounded field, and the grounded one caused it to overcharge. IF HE HAD SWITCHED the wires, HIS HARNESS WOULD HAVE FRIED as the IGN would have been feeding a DEAD SHORT!!!
  5. 68_Valiant_Wilson
    27
    1
    Jul 31, 2017
    Clinton
    Local Time:
    3:45 PM
    UPDATE: I took the new alternator to advance auto where they said they couldn't test it and then I took it to napa where they said it was bad. The alternator is moving now but it's still bad.
  6. 68_Valiant_Wilson
    27
    1
    Jul 31, 2017
    Clinton
    Local Time:
    3:45 PM
    Where exactly can I get a alternator that isn't a cheap rebuilt? The one that's bad came from rock auto. Do I need to get a different one from rock auto?
  7. toolmanmike
    toolmanmike Moderator Staff Member FABO Gold Member
    62,328
    51514
    Jan 18, 2006
    Iowa
    Local Time:
    2:45 PM
    What brand of rebuild was it?
  8. 68_Valiant_Wilson
    27
    1
    Jul 31, 2017
    Clinton
    Local Time:
    3:45 PM
    PURE ENERGY
  9. pishta
    pishta I know I'm right....
    21,358
    10759
    Oct 13, 2004
    Tustin, CA
    Local Time:
    12:45 PM
    alternators have 2 bearings in them (or one bearing and a bushing) Its possible to crack it open and find what the issue is, probably a screw or brush piece jammed in between the stator. If it is spinning but no charge, check brushes. alternators are pretty simple, 3 moving parts if you include the 2 brushes!
    Hint: the brushes can be retained in the retracted "install" position by a paperclip.
  10. toolmanmike
    62,328
    51514
    Jan 18, 2006
    Iowa
    Local Time:
    2:45 PM
    It was less than $20. You can't expect high quality there.
    • Agree Agree x 2
    • pishta
      21,358
      10759
      Oct 13, 2004
      Tustin, CA
      Local Time:
      12:45 PM
      20 bucks gets you an old alternator core dipped in solvent and reboxed.....
      but seriously a rebuilt alternator may contain 2 new .60 cent brushes and 2 buck bearings...and a box.
      • Agree Agree x 1
      • 69_340_GTS
        69_340_GTS Well-Known Member
        4,581
        3022
        Jul 11, 2014
        Torrington, CT
        Local Time:
        3:45 PM
      • jos51700
        jos51700 Green Bearing thread connoisseur
        5,953
        2730
        May 24, 2009
        Bel-Ray
        Local Time:
        2:45 PM
        I have better luck with twenty year old factory salvage yard parts than I do rebuild crap.
        Had that issue on a neon starter just last week. Dead solenoid, right out of the box. guess who didn't test it first.....
      • 68_Valiant_Wilson
        27
        1
        Jul 31, 2017
        Clinton
        Local Time:
        3:45 PM
        I guess I'm glad I'm not the only one...
      • Tooljunkie
        Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
        20,068
        22191
        Jul 22, 2017
        Manitoba
        Local Time:
        2:45 PM
        I might suggest the bolt for the adjustment was too long, damaging the stator.
        Another is the housing bolts werent tightened in factory evenly causing rotor to bind.
      • 67Dart273
        51,434
        20387
        Oct 14, 2010
        Idaho
        Local Time:
        12:45 PM
        I used to blow these things up "real regular." The original setup on my 440-6 '70 RR had a very small pulley, and I figured one time "if I remember" the crank to pulley ration was around 4:1. This means if you spin the engine up to 5 or 6K the alternator is making 20--24000 RPM. The stator would "vibrate" little notches in the alternator case halves where the "nubbins" located the stator in the cases. They would then "sit" crooked and actually rub the rotor/ stator. The windings would vibrate loose, and wear the insulation off between turns where they crossed. You could lift the hood at night, rev the engine, and see a really interesting little "light show." All sparkly and stuff
