The '88-'91 truck/van alternator is a wise pick, preferably the (Nippon)Denso 40/90 or 50/120 unit. The 40/90 is more than plenty unless you're running massive amounts of electrical equipment (giant stereo, lights everywhere, dual A/C, etc). The lower first figure indicates output capacity at idle, higher second figure is the max output rating at speed.
All '70-up regulators look alike, but are not all the same; none of the pre-'79 ones will dependably or durably handle the higher field current draw of the '79-up alternators, and there was another field current upgrade in '89. So to avoid cooking the regulator and conking out the charging system while you're in the middle of using it, install
this kind of HD adjustable regulator.
To avoid an expensive and sad car-b-que (wire fire), read
this (skip the halfaѕѕed, crummy advice from those dillweeds at Mad Electrical) and pick your charging circuit upgrade method/s (and do them) before you proceed with the alternator upgrade.
Choose your alternator carefully; the "100% New!" units are just as variable in quality as the "remanufactured" ones.
