I don't comprehend hieroglyphics. What is the question. Do you have wiring diagrams? If not wander over to "MyMopar" and download one of the two-page aftermarket diagrams. These are not often as detailed or complete as OEM but somewhat easier to follow at times
Also wander around there and see if they have a 66 service manual posted. You may have to settle for Doge / vs Plymouth, etc
The two you have in your hand appear to be the ammeter connections. BE CAREFUL. They are hot at all times, large amp capacity, and ARE NOT FUSED. If you are trying to fire the car with the instrument cluster out, bolt then together and tape them off.
I haven't a clue what you are getting at in the bottom photo
On your '66 Dart, you are seeing the standard wiring for that car.
The Black wire from the alternator does not go directly to the ammeter. It goes to the main splice.
The main splice is a welded junction joining the power sources (alternator and battery) with the feeds to the circuits.
Power circuits for a '66 Dart (hardtop or sedan)
What are you trying to accomplish?Can I ask you then would I be able to disconnect the wires off the welded Junction and just add them to my new 10 gauge wire I was planning to add through the firewall with a ring connector and then continuing the 10 gauge wire to the starter relay
