Aluminum Block Slant Six Head Gasket Source?
Walt Jackson
Does anyone have a source for these?
--Walt Jackson
I have the felpro set nos...and AL / motor. Neat stuff. Lol
Could you o ring the head and run a dead soft copper head gasket? $250 for a HEAD GASKET is hard to swallow but if you got one of probably 50 running AL slants left today maybe its not an issue.
Man I remember when I was about 14 (1978) taking a sledge hammer to an aluminum block slant 6 to bust the cylinder sleeves out of it for SCRAP!!! after removing the sleeves I picked the block up myself and loaded it in the truck. Probably got about $5 out of the damn thing!!!
Aluminum blocks are open deck. No room to o-ring. If you want to run an Aluminum block, you will basically have no choice but to ante up for one of the expensive gaskets. FYI, I believe the ones available at .org are reusable.
jus sayin...
I found a source for the original gaskets.
Olsons Gaskets in Port Orchard, WA
(360) 871-1207
olsonsgaskets.com
jus sayin...
O ring the 63 or later iron head.....jus sayin'
does not matter what side you O-ring if its a non-receiver job
Call Cometic. They'll make you whatever gasket "will work".
Olson's Gaskets
360-871-1207
olsonsgaskets.com
Good luck with your project.
--Walt Jackson
