Aluminum, cast iron looking master cylinder
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
Reading my latest (Feb 2022) Mopar Action (which has a significant brake article.)
Referred to an aluminum master cyl that shaved about 4 lbs from the car BUT looks like a stock cast iron mc. Not much different price than a rebuilt cast iron one.
https://www.force10brakes.com/home/...sc-drum-and-disc-disc-applications-p235514315
(On your phone you have to scroll down as there is an anoying give us your email request at the top of the page)
Looks suspect to me...how did they get that color? Let us know, that would be a great addition instead of a rusty cast iron one.
I have received my cast aluminum master cylinder from Force 10. Shipping was fast; less than 3 says from the time I placed the order online late in the day till when I received it. Besides being double boxed, it was also sealed in a plastic bag
other than no “cast iron” finish, it looks just like as shown in the magazine article in Mopar Action
I didn’t compare it weight-wise to a similar cast iron master cylinder but there is a definite difference in weight. I will know more and report back once I get it installed.
Can you post a link. Thanks
Of course it's going to be awesome! Because I just in the last couple days bought and received my doctordiff 4 bolt to 2 bolt adapter so I could ditch the cast iron master cylinders, lol. Figures. Looking forward to the reviews!
Hi Don,
I’m eager to hear if it’s a true bolt in master cylinder, brake lines and all…
it appears it will be a true bolt-in - the front and rear port size is correct - front fitting larger than the rear
I have my brake pedal assembly installed and the master cylinder slides right onto the mounting studs no problem.
I can’t verify fitment with a manual brake pushrod as I don’t have one and haven’t decided yet to go manual or power.
This M/C also fits my rebuilt Midland Ross power booster M/C mounting studs
