aluminum magnum head question
jos51700
Green Bearing thread connoisseur
Bel-Ray
Are mopar performance aluminum #Part #: 312-P5153847
heads just re labelled Edelbrock heads, or are they different?
What are generally considered the best STREET USE bolt on aluminum heads for a magnum engine on the market right now? The cam will never go over a mid range torque cam. Car is a dart, currently carburetor 4-speed but will go efi and may go back to automatic.
Thanks all! Recommendations on shops to go through them for checking over prior to install are appreciated too.
I'm not sure about it, but i think those are repacked eddy heads with mopar logo. Same as LA engine, eddy 60779->849 mopar heads, repacked with mopar logo.
Tell more your combination.. best magnum heads??? Maybe cast iron rt heads or those aluminum heads..
The car is going to use a mid range cam?
Skip the aluminum heads. That is now a waste of money.
As per out earlier convo... the best bang aluminum head OOTB is the Edelbrock head. I would purchase right from Hughes engines for example with the prep work all ready done.
Fellow FABO'ers like OU812 or MRL can also do this work for you.
