MountainMan73
This mark on the front housing doesn't look right.
You could check the resistance from the Batt terminal on the alternator to the housing. It should be isolated.
On the back we see the three positive and three negative diodes. The positive three are isolated from the housing. One looks like it may be out of place?
Since its already off the car, and I'm a little suspicous of that mark on the front and the diode, for now lets hold off on field current check.
You could remove the grounded brush, and then check for short in the field circuit by touching one probe to the fiueld terminal and the other proble to the housing.
[/QUOTE]
That mark I bet is from the bracket where that bolt goes through. I just tested the VR and I had resistance checking it the way you recommended.
