Ill check btut im sure its tight!Loose drive belt for the alternator?
We need to know what is it doing?Anyone know what would cause my amp gauge to fluctuate.
Fairly common at slow idle, especially with a foot on the brake pedal (brake lights on).Its worse when i turn on my blinkers!
New is not always good. Why was the VR changed.Ive got a new V regulator and new ceramic resistor installed.
Shouldn't be relevant; except as noted above, if this is an add on, it can create an additional load or resistance in the shared portions of the circuit.It has elec ignition. New coil wires plugs etc.
noWith the blinkers is super normal.
Without that type of load could be several things.
Did it do it before the VR change?
first video!Any of these look familiar?
New video by Dana Nance
Round back Square back?Any of these look familiar?
First video i started at idle and then increased the RPM, this is a Round Back Alt with an Electronic version of the electro/mechanical regulator. Notice how it was giggling at lower speeds then stabilized at higher speeds. TYPICAL of all Mopar alternators at lower RPM the input shaft to the alternator is not spinning fast enough generate enough current to run everything well. (many replacement alternators have a larger diameter pulley on them turning the input shaft even slower. In the videos comparing the square and round back, note the square has a larger dia pulley and even though the square is supposed to be a better alternator it did not preform as well as the smaller pulley on a round backfirst video!
loose terms...Round back Square back?
As long as it's charging when it's supposed to I would call it good. Idling in gear with the brake on and a 60 year old car the amp meter will probably jump around a bit. My Swinger idling in gear with the ac on will kill the turn signals. Pop it in neutral and back they come. Idle speed with an old roundback is slow enough it doesn't put out enough to keep up.Any of these look familiar?
I have never ever once heard this "N and P" type designation. I don't think you said so, so let me. What you are calling "P" type has one end of the field grounded and was used up THROUGH 1969round back
you can identify a standard pre 71?? mopar alternator by its round case back
Its known in some places as a P type alternator because the basic 2 wire 1 ground regulator takes 12 volt switched from the loom and applies a proportion of that to the single field connecter on the alternator. the other end of the field in the alternator is connected to the alternator case, which is ground. The regulator is on the positive side of the field coil
(+) switched 12 volt --->regulator--->field connector---->ground inside alternator case (-)
work with the black hump shaped regulator with F and Ign connectors, and a ground connection through its mounting
Square back:- later mopar alternator has a square back to the case used until 198? maybe early 90s
Known by some as an N type alternator
not sure if this N type P type naming thing is a US or a Euro slag term to differentiate easily between types
1 end of the field coil to 12 volts the other end of the field coil via the second field connector goes to the regulator
if the regulator puts out 12 volts the voltage across the filed is zero (12 at both ends) and the alternator does not charge the battery, if it puts out less than 12 volts there is a difference in potential between the 2 field terminals hence there is a current in the field, if it puts out zero volts it acts as ground and the field gets maximum voltage across it and a bigger current in the field.
(+) 12 volt----->field connector 1-------> field connector 2------>regulator----->ground (-)
in 1 case regulator near the + side and in the other case the regulator is on the - side
N type regulator sits in the negative portion of the field circuit between the alternator and ground i.e closer to battery negative
N type alternator always has two field connectors that are totally insulated from the alternator casing.
P Type may have two field connectors But usually has only one.
A second field connector if it exists is just bolted to the case with no fibre or plastic washer under it, hence is grounded in a visible external position rather than inside the case.
an internal regulated alternator (neither of the above) could be either, all the electronics for the regulator is inside or bolted to the back of the case in a plastic module.
you can spot a p type alternator with a continuity tester, should beep if you connect it between field connector and case
N type will only beep if you connect it to both field terminals, it should not beep with 1 end of your continuity tester on the case and the other on a field terminal
Dave
The videos are NOT the OPs videos. I was using MY videos to offer up a visual on what the OP was seeingVoltage regulators switch the alternator between fully on and fully off with very little in between. However they typically switch faster than what's shown in the video. This is looking like the regulator has an unusually slow switching speed. Not ideal but not truly scary either. Switching too fast has its own problems.
Older electro mechanical regulators switched at a fairly low rate, you could easily see the relay actuating. I don't remember, anymore, I'm thinking around 1/2 a second or so. The inductive effects of the field keeps things "more even" that the on/off action of the old relay setup would suggest. Also, most ammeters have at least some lag in their readingsVoltage regulators switch the alternator between fully on and fully off with very little in between. However they typically switch faster than what's shown in the video. This is looking like the regulator has an unusually slow switching speed. Not ideal but not truly scary either. Switching too fast has its own problems.
loose terms...
Round Back indicates the older style alternator with a grounded field system and uses the small square 1 wire in 1 wire out electro/mechanical VR
Square Back is the newer style alternator with a isolated field system and uses the larger VR with the triangular connector
@Mattax did a great job outlining the differences in this post
Identifying Chrysler Alternators (1960-1976)
Grounded Field Alternators
Isolated Field Alternators
