Another Episode of "WHATS THIS PART "
RAT ROD AL
MOPAR ARCHEOLOGIST - one parts hoard at a time!
Lecanto Florida
Tonight I have a few different parts I need ID'ed. Thanks in advance to all you experts that chime in !
#1
I have a electric trunk release from something Mopar . Any Ideas ?
#2
of coarse no P/N . Not sure if a hood or trunk latch and for what ?
#3
#4
A/C part maybe .
I'm thinking #2 may be a hatchback or trunk latch that had an offset key and handle arrangement that mounts to another plate. I'm trying to remember which FMJ or K-L car used that arrangement...
#1 trunk, I say mid to late 70's after they trashed the vacuum release and before the electric all in one units.
#2 trunk latch. 70 fury and Cuda look like that but rod is longer
#3 is the cancel ring from a steering wheel
#4 is spare tire bottle holder thing. E body's came with option of space saver spare. The aluminum bottle fills it. The part you have holds that bottle.
What does a space save bottle bracket from a Volre/Aspen/cordoba look like? Those 14" and 15" space saver that are all over the place. With the diamond tread pattern. Way different than 70-71.
I believe @toolmanmike installed an electric trunk latch/release in his 1972 Dart.
He could probably tell you what that #1 trunk solenoid is from.
Calling @Professor Fate on #1 ever seen anything like this ?
I'm thinkin' early to mid 70s Imperial- it's similar to this one, but not exact...
This one's a B body, but the bracket is quite a bit different:
BTW, #2 looks suspiciously like a Ramcharger/Pickup bucket seat latch, so it's probably from something similar- maybe a bench seat?:
I worked on a 76 ish full size mopar and it had power door lock units that looked just like that trunk unit in #1
