[SOLD] Another, super special, double secret, almost Christmas, get it off the shelf, $2, $3, and $5 sale
physixx
Edison, NJ
Here is the 3rd installment list of more small items for the Christmas sale list! Some are the same that didn't sell yet and some are new items. :)
$2.00 ITEMS
1 pair of the nylon truck lid hinge shoes, $2.00 for the pair
A pair of chrome interior coat hooks for the 64-68 Dodge and Plymouth cars
2 glove box door latches with attaching screws, $2.00 each
SB distributor hold down clamps $2.00 each - 2 SOLD
Left side door handle pivot thingy that the push button activates to open the door
2 SB carb throttle cable return spring brackets, $2.00 each - BOTH SOLD
Assorted vacuum nipples, $2.00 each
Rear leaf spring OEM clamping bolt and nut.
Pair of front strut rod nuts, LCA end
8 ¾ center section housing fill plug - SOLD
NOS ½” valve stem extensions P/N 2660315. Set of 4
2 NOS flasher units. $2.00 each - SOLD
$3.00 ITEMS
New pair of front wheel bearing seals for the 11” drum brakes, Sealed Power #N-17110
New pair of front wheel bearing seals for the 10” drum brakes, Sealed Power #N-17115 - SOLD
3 SB harmonic balancer bolt. No washers though. $3.00 each - 1 SOLD
New Britain # P-92 inside door handle retaining clip removal tool - SOLD
2 left hand thread, ½” axle studs and nuts. $3.00 for both
$5.00 ITEMS
New adjustable header collector locking tabs, nuts and bolts with an extra.
2 sets of 2 groove valve stem keepers, $5.00 per set - 1 set SOLD
Bower motor plastic fan (squirrel cage)
2 ½” muffler clamps for both - SOLD
2 neutral safety switches w/ the special metal washers 3 wire, 1968 and up, $5.00 each
Trunk light that illuminates when you open the trunk - SOLD
Set of 12 aftermarket 8 ¾ ring gear bolts
New drum brake residual pressure valve from Master Power Brakes. 10 PSI
Single used ratchet strap from “Keeper Products”. 56” total length & 2 ¾” wide
Used truck/trailer, 7 pin wiring connectors, flat pin design by Pollak
Ken
Edison, NJ
Pay now or after I add some more ? Either way is fine with me. Do you have any valve cover grommets for pcv and breathers on the Mopar Performance covers ?
Actually I will also take the muffler clamps and the trunk light if they are still available.
Ken ill take 1 disty hold down and both throttle brackets. I still have your info send me a total.
Ill pm you my info if you dont still have it
Gary
