Another vert. ?
pikewi
Comfortably numb
WI
Another on my 68 cuda vert.
I got the fabric top disattached from the trunk area thanks redfish.
How is it attached at the sail panel area and the front part above the w/s?
I know I seem a little ignorant but my service manual doesn't adress converetibles. Sorry
Pike- the well read
Peel the rubber weatherstrips out of the sides where windows seal. Remove screws now revealed from that stainless trim.
At front remove trim caps from underside of header ( painted or stainless ).
note... There should ba a pair of tiny wire thingies on the rearward bow / sail panel area. Dont loose those. They control how the top folds on the way down.
Thanks again RedFish.
I need to muddle my way thru this top thing so I can get down to something I know a little about. I appreciate your help.
Pike - the appreciative curmudgeon
