petty437 FABO Gold Member FABO Gold Member Joined Feb 5, 2014 Messages 428 Reaction score 308 Location Kent, Ohio Feb 10, 2020 #1 On a 63-66 Dart, does anyone know where the hole is supposed to be in the A pillar (above the passenger kick panel)? I need to drill it & would like it to be close to the original location. Thanks!
Alaskan_TA Well-Known Member Joined Nov 12, 2004 Messages 6,415 Reaction score 5,289 Location PA Feb 10, 2020 #2 Not sure about those years, but on newer cars that had no radio or antenna, there was a rubber plug in the hole. If adding a radio, pull that plug & the grommet around the antenna lead would replace it.
Bogie Well-Known Member Joined Sep 6, 2006 Messages 296 Reaction score 162 Location Queens,NY Feb 10, 2020 #3 Not my photo but hole can be seen
Tims 66 Cuda Mopar mid life crisis Joined May 28, 2018 Messages 500 Reaction score 175 Location Poquoson, Va Feb 11, 2020 #4 Agree With Bogie, thr hole is in the same place on my 66 Barracuda. Still have the original antenna w/ cable and grommet. Tim
