Built this for my dirt track factory stock. The rules require 14"vacuum at 1200 and 175psi max cranking and .450" max lift Cam. flat top 4 eyebrow pistons 365cid max. cast iron exhaust 4412 holley 500 2bbl stock cast or aluminum intake.
360+.030 SP 405 pistons between 8.9 and 9-1 static comp.
EQ mag heads with LA manifold
diguised aluminum 68 340 intake P4532059
340 LH and early magnum dakota RH exhaust int 2 1/4 inch pipe
Bullet custom cam 286--230@.050--.3027 lift--110 separation---degree to 106 Hydralic per rules.
can anyone run this thru there program and give me a rough idea on HP--Torque ?
when racing runs betweeen 4000 and 6400 rpm.
Thanks
PS what happen if I install cam at 104?
Thanks
