Cuda416
Yours was also a runner.
Keep that in mind when buying a used engine.
Very true, that's why if this goes forward, I'm insisting on pulling the head to see inside.
Honestly I'm pretty sure your kid wants to drive the car, I would redo the head and run it find another block in the mean time to build and when the time comes at least you have a redone head to slap on your fresh block. I had a simlular scratch in the bore and just ran it that way. That crack at least didn't turn out to be a crack which is good.Dang it, the "run" distracted me. Thanks for spotting that...
I have seen that sort of transverse "crack" develop when atmospheric moisture, condensed in a cylinder that had open to atmosphere valves, and sat in the cylinder over a long period of time. Granted I have only seen it in a V8; but a slanty is half a V12 right?. The moisture etched the wall, and it looked like a crack, and I could even sorta catch a fingernail in it, cuz metal was in fact missing. But it wasn't a crack.
I have seen what happens to a cylinder when water freezes in the jacket, and the frost-plugs didn't pop. And it can be ugly. Your crack, if it is a crack, ain't that kindof crack. So what kind of crack could it be? That left everything else intact?
IMO, it's too far down to affect the engine performance in any way. As soon as the head is back on, you can pressure test both the cylinder and the cooling system, and see what's what. And all it costs you if you don't fully torque the headbolts, is time. And not even a whole lot of that.
If that was a crack, the piston, combustion chamber and valves would be clean as all hell from coolant getting into the cylinder. Also, cracks don't scrape off. It's not a crack.
My guess is, it has a broken ring and that's a carbon trail from the space in that ring. Seen it before.
yeah, you just brush some dye "penetrant" on there. It's thin like water, and you would only need 1/4 cup or so. Then you wipe it off, or wash it off with brake cleaner on a rag. Then you lightly dust it with the "developer" powder (which just looks like white talcum powder to me), and the dye will seep back out of the cracks, and will be readily visible to the naked eye. I don't know for sure, but it doesn't look like it's very expensive, and it doesn't take any extra equipment, or much expertise to use.Just ask your machinist for some dye that he would use to magnaflux with. Or where to get some. Clean up that cylinder with some steel wool or wire wheel and check it. Simple deal.
...….This is how I've seen it done....
I once worked as a machinist in a company that cast SS and bronze propellers. They used the crack-checking dye all the time to detect surface cracks which appear frequently in the casting process. Once detected, they would grind or electrically "scarf" out the crack till they find solid metal, then weld it back up.I totally agree the process is more involved than "this works and that doesn't" and largely depends on the situation. I'd juts never seen the "Dye" method before.
Back years ago when I worked in Trailer shop , Would have to find and repair leaks in Tankers and ect, We would use something similar , As I remember it was A purple dye in a spray can, simply spray it on the suspected area and if any cracks the dye would penetrate the crack. Not sure if its the same stuff as the machine shops use. And maybe they don't even use it anymore .But a machinist I used back in the day did.Dye? I've never seen nor heard of that. The "magnafluxing" I've seen used an actual electromagnet and iron dust. A crack attracts the dust differently than a non crack area...
