Anybody running 440 4006452 heads on a 383?
Mopar Performance Issues
  1. 383FormulaS67
    383FormulaS67 Bob
    116
    31
    Jun 8, 2018
    Ohio
    Local Time:
    10:23 AM
    My 67 383 is .060 over, block has been decked, flat top pistons, .105 piston depth in the hole. Engine is at machine shop, and I'm try to pick heads for it. Had 516 small valves on it. I'm interested in RV heads for better cooling, unleaded fuel etc. Do not want to over spend, if that's possible. Looking for someone with 452 heads on their 383 and how they're set up/performed.... Shop said we'll need to go to dome pistons to help keep compression up. Looking into Lunati Voodoo cam 475/494 lift 262/268 duration w/323 gears. Thanks!
    • Like Like x 1
    • jaws
      jaws I put the fun in dysfunctional FABO Gold Member
      3,509
      1904
      Sep 11, 2006
      Strasburg Colorado
      Local Time:
      9:23 AM
      Had them on my 383 in my race car. Are you sure your pistons are a tenth down hole?(that's a lot) I was running flat tops that came .020 out, witch is factory.
    • twayne24365
      twayne24365 Well-Known Member
      1,543
      350
      Jun 18, 2013
      Maryland
      Local Time:
      9:23 AM
      My 383 has 516s 2.08/1.74 valves, motor ran mid 12s in a b body.... if pistons really are that far down better stick with the closed chamber heads, spend a couple bucks in a good valve job w/ hardened seats
    • swing69
      swing69 fightin' socialism
      3,857
      918
      Jul 28, 2008
      Central Socialist NJ
      Local Time:
      9:23 AM
      I have a set of rebuilt 452 heads, all ready to go. Never installed. $250 if interested. I'll be headed out to Ohio in mid July to "mid Ohio" fo races, I could bring them out..........Mike
    • 383FormulaS67
      383FormulaS67 Bob
      116
      31
      Jun 8, 2018
      Ohio
      Local Time:
      10:23 AM
      yes, shop started on it yesterday. Older rebuild from previous owner 20 plus years ago low miles overall, But was surprised on the .105
    • RustyRatRod
      RustyRatRod Weenie idiot loser. FABO Gold Member
      58,009
      28088
      Jun 7, 2010
      Georgia
      Local Time:
      10:23 AM
      I think 452s would ba backing up, but what do I know?
    • 383FormulaS67
      383FormulaS67 Bob
      116
      31
      Jun 8, 2018
      Ohio
      Local Time:
      10:23 AM
      Thanks Mike will follow up
    • 383FormulaS67
      383FormulaS67 Bob
      116
      31
      Jun 8, 2018
      Ohio
      Local Time:
      10:23 AM
      So I can just put 1.74 valves in my 516 heads and move on?
    • 383FormulaS67
      383FormulaS67 Bob
      116
      31
      Jun 8, 2018
      Ohio
      Local Time:
      10:23 AM
      What do you mean backing up, going down in compression??
    • brian6pac
      brian6pac Well-Known Member
      4,321
      2844
      Nov 15, 2016
      N.E.Ohio
      Local Time:
      10:23 AM
      Yes put the big valves in the 516's, keep the closed chambers
      • Like Like x 1
      • RustyRatRod
        58,009
        28088
        Jun 7, 2010
        Georgia
        Local Time:
        10:23 AM
        Just all the way around. I much prefer a closed chamber head....and you already have them. I would put big valves in the 516s, and get a zero deck height piston for that 383. Hardened seats on a street car are really not necessary, especially as light as the A bodies are.
        • Like Like x 1
        • 383FormulaS67
          383FormulaS67 Bob
          116
          31
          Jun 8, 2018
          Ohio
          Local Time:
          10:23 AM
          Roger that, sounds good.
        • 383FormulaS67
          383FormulaS67 Bob
          116
          31
          Jun 8, 2018
          Ohio
          Local Time:
          10:23 AM
          Thanks Rusty
        • RustyRatRod
          58,009
          28088
          Jun 7, 2010
          Georgia
          Local Time:
          10:23 AM
          Sure. Opinions vary, and I am sure others will disagree with me, but my thinking is, you HAVE the 516 heads. To me, unless you have 2K to drop on aluminum heads, you'll come out less expensive using what you have. Unless you're trying to build a 600 HP 383, the 516s will work good with a few changes.
          • Like Like x 2
          • Agree Agree x 1
          • fishmens67
            fishmens67 Well-Known Member
            6,836
            3951
            Nov 10, 2012
            idaho
            Local Time:
            9:23 AM
            Part # of piston ?
          • 383FormulaS67
            383FormulaS67 Bob
            116
            31
            Jun 8, 2018
            Ohio
            Local Time:
            10:23 AM
            True, I need to spend it wisely. I want to take advantage of the 383 and get it over 6,000 rpm. Will it be OK, with this set up?
          • dano
            dano Evil Handy Man
            2,736
            736
            Aug 22, 2005
            Gresham, Oregon
            Local Time:
            7:23 AM
            I'm not surprised at the 0.10" in the hole. The 440 my dad rebuilt was over 0.1" when he tore it down. KB pistons and 915's fixed it right up.
            • Like Like x 1
            • twayne24365
              1,543
              350
              Jun 18, 2013
              Maryland
              Local Time:
              9:23 AM
              I would go 2.14/1.81 if I was paying to have it done, but all the stock iron heads are going to flow roughly the same in stock form, so the compression increase with your 516s over a set of 452s is going to help you a ton more over very few CFM of flow.
            • Jadaharabi
              Jadaharabi FABO Gold Member FABO Gold Member
              6,724
              7046
              Jan 8, 2016
              Peoria, Illinois
              Local Time:
              9:23 AM
              67 383 was not .020 out of the hole but a 69 383 Road Runner was out of the hole.
              Next.
              Why would you want to put big valves in a small Port head.
              The 452 are great heads use them.
            • BigBlockMopar
              BigBlockMopar BigBlockMember
              1,743
              743
              May 1, 2011
              Netherlands
              Local Time:
              4:23 PM
              IMO the engine will act a low CR smogger.
              I've had an openchambered 383 once (with a mild "Roadrunner/268 dur" cam in it) and it was a turd that liked to ping easily too.
              • Like Like x 1
              • Thanks! Thanks! x 1
              • jaws
                3,509
                1904
                Sep 11, 2006
                Strasburg Colorado
                Local Time:
                9:23 AM
                My car was a 69 Dart
              • jas0162
                jas0162 Well-Known Member
                477
                292
                Apr 23, 2014
                kansas
                Local Time:
                9:23 AM
                If you put the 452 heads on a 383 with the pistons down in the hole that far the compression ratio will be around 7.5 or so. Keep the 516s if you are keeping those pistons. 383 will run great with a stock pair of 516s, a mild cam, and pistons that come up all the way.
                • Like Like x 1
                • RustyRatRod
                  58,009
                  28088
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  10:23 AM
                  'Swat I've been tryin to tell him. With great resistance.
                • fishmens67
                  6,836
                  3951
                  Nov 10, 2012
                  idaho
                  Local Time:
                  9:23 AM
                  I have never seen a 383 with a positive deck piston from the factory, the closest I've seen is 68 hp and they were close to zero deck, but still slightly down in the hole.
                  • Agree Agree x 1
                  • jaws
                    3,509
                    1904
                    Sep 11, 2006
                    Strasburg Colorado
                    Local Time:
                    9:23 AM
                    3A346E98-22A4-405D-ADD9-343D3D15C1E5.jpeg BCEE1599-2EAC-4CF9-8BEA-B1F4F4685712.jpeg
                    Can’t find the order form, but they a custom JE pistons only number on them is 315F, think that is the raw forging number.
                    • Like Like x 1
