Anybody running a solid roller on the street as a driver?
I was going to run a hydraulic roller but my friend thinks I will not be happy with it the hydraulic lifters. That I should go solid roller.
here's my combo so far.
340 - 20 over
10.3 to 10.5 to 1 compression
379 crank mopar crank off set cut so i think its a 381 now
Compstar rods
custom ross pistons
W2 race head long valve 11/32 stem just a little work done to them
flow numbers stock are 260 so they should flow just a little more.
still have to flow them.
Harland sharp or T&D Rockers
Cam comp cams solid roller or hydraulic Roller???
Lifters comp cams ?????
Smith brothers push rods
forgot the name of the chain.
victor Jr w2 intake
750 carb
ATI balancer
8 bolt Ram flywheel
70 duster 4 speed 4.10 gears 27" tall rear tire
may go with passion 5 speed
340 - 20 over
Compstar rods
custom ross pistons
victor Jr w2 intake
750 carb
ATI balancer
8 bolt Ram flywheel
