It is has a forward mount cable by design. I used the bracket supplied for the 727 trans. I would suggest you look up part number 81120 on the Summit webpage and read. See if it fits your requirements. It is a likable shifter and even more so if you are not the one having to install it. I would prefer a rear mount cable shifter for an "A" body because of space in which to work with. Now, that being said. Your situation might be different. You might not have full length headers. You may have replaced your torsion bars with an aftermarket setup eliminating them. You might have a shop lift to work under instead of lying on you back under the car. You might have the hands of a pianist and can work in BMW spaces leftover as an after thought by some german engineers. These things I don't know. What I do know is. It's a solid, well built shifter that gets the job done and will work in the application for which you outlined.
