Anyone had fuel sender leaking
Fuel and Air Systems
  1. bruno
    bruno Active Member
    44
    37
    Mar 29, 2012
    melbourne Australia
    Local Time:
    5:19 PM
    i have changed the seal but still leaking
  2. Bad Sport
    Bad Sport HALF A BUBBLE OFF Staff Member FABO Gold Member
    35,503
    14836
    Jun 12, 2010
    The Wolverine
    Local Time:
    6:19 PM
    Did you by chance put a new sending unit in and use the lock ring that came with it.
    If so, that might be the problem, the replacement lock ring is thinner and and doesn't seal as well.
    • Agree Agree x 3
    • Dusterdenovo
      Dusterdenovo Contentedly Old School FABO Gold Member
      851
      1496
      Dec 10, 2011
      British Columbia
      Local Time:
      3:19 PM
      I made a washer/spacer out of the side of a WW fluid jug, using the gasket for a pattern. I put it under the aftermarket lock ring and tightened it up. All fixed.
      • Like Like x 2
      • AJ/FormS
        AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
        15,910
        4803
        Jan 19, 2014
        South-Central Manitoba,Canada, 900ftelevation
        Local Time:
        5:19 PM
        You will know when the gasket pack you make is thick enough, by the difficulty required to insert the lock-ring and turn it. Usually I have to use a hammer and punch to secure the ring far enough up the ramps, to squish the gasket into sealing mode.
        • Agree Agree x 2
        • halifaxhops
          halifaxhops It's going to get stupid around here! FABO Gold Member
          50,863
          18605
          Jan 20, 2014
          CENTRURAL, PA
          Local Time:
          6:19 PM
          • Like Like x 1
          • Dusterdenovo
            851
            1496
            Dec 10, 2011
            British Columbia
            Local Time:
            3:19 PM
            I've had to pull my sender out a couple of times so I made a little wrench for snugging up the lock ring. 20181204_180940.jpg 20181212_115129.jpg
            • Like Like x 8
            • Tooljunkie
              Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
              9,343
              7834
              Jul 22, 2017
              Manitoba
              Local Time:
              5:19 PM
              Look close,perhaps the solder joint or electrical connector is the issue.
              Have seen 2 with leaking solder joints around the tube where gas line connects.
            • 1994redram
              1994redram FABO Gold Member FABO Gold Member
              1,110
              556
              May 9, 2012
              Oklahoma
              Local Time:
              5:19 PM
              Mine leaked around the fuel hardline where it passes through the body of the sending unit. I cleaned it really well and soldered it up. It's been holding leak free for over a year.
            • mvh
              mvh FABO Gold Member FABO Gold Member
              1,395
              171
              Dec 17, 2007
              Menlo Park, CA
              Local Time:
              3:19 PM
              JB Weld would probably do the trick if you are nervous about soldering something that has been soaking in gasoline for fifty years...
            • bruno
              bruno Active Member
              44
              37
              Mar 29, 2012
              melbourne Australia
              Local Time:
              5:19 PM
              Thanks everyone for your help I think I might. Need to solder round fittings as have new gasket and ser
            • pishta
              pishta I know I'm right....
              14,390
              4043
              Oct 13, 2004
              Tustin, CA
              Local Time:
              3:19 PM
              you should sell those. :)
              Lead solder has a melt point of 395 F, Gasoline has an ignition temp of 495 F, you'll be OK soldering.
              • Agree Agree x 1
              • DemonDave
                DemonDave I'm a little devil...
                742
                187
                Oct 17, 2004
                Victoria, BC
                Local Time:
                3:19 PM
                Mine just started leaking from the rubber grommet that the wire passes through. Do I have to drop the tank to change the sender or is there enough clearance between my axle housing and the tank to wiggle it out?
              • RedFish
                RedFish Well-Known Member
                23,291
                2164
                Sep 5, 2007
                Local Time:
                5:19 PM
                Stands under the frame so axle hangs down. I place one stand under drivers side so remaining fuel goes to low side, and can work the sender out.
              • DemonDave
                742
                187
                Oct 17, 2004
                Victoria, BC
                Local Time:
                3:19 PM
                Did it today, very easy. So easy that I did it twice! Turned out that the plastic screen strainer dealey on the end of the pick-up tube had been shoved on all the way at the factory effectively plugging the end of the pick up tube. Found that out after leaving my driveway and promptly running out of gas...
                The second installation went much better after I yanked off the strainer and tossed it away. Now I know why the one that came out had no strainer on it... I'm not the first to go down this road apparently!
                The longest part of the job was draining the tank, the re-and-re (and-re) was barely a ten minute job.
                All good now. No leaks and my gauge even still works. Win!
              • krazykuda
                krazykuda Well-Known Member FABO Gold Member How-To Section Editor
                47,607
                12581
                Aug 20, 2007
                Orland Park, IL
                Local Time:
                5:19 PM
                • Agree Agree x 1
                • krazykuda
                  47,607
                  12581
                  Aug 20, 2007
                  Orland Park, IL
                  Local Time:
                  5:19 PM
                  I think that you can wiggle it...
                  (that's what she said... :D)
                • krazykuda
                  47,607
                  12581
                  Aug 20, 2007
                  Orland Park, IL
                  Local Time:
                  5:19 PM
                  Why not put some silicone sealer on the wire and grommet to seal them... I would try the clear RTV...
                  Then you also don't have to pull the sending unit...
                • krazykuda
                  47,607
                  12581
                  Aug 20, 2007
                  Orland Park, IL
                  Local Time:
                  5:19 PM
                • krazykuda
                  47,607
                  12581
                  Aug 20, 2007
                  Orland Park, IL
                  Local Time:
                  5:19 PM
                  The strainer keeps large chunks of dirt and debris from getting into your fuel system, running without one may open you up for dirt and debris from damaging the fuel pump and/or clogging your in line fuel filter...
                  There is a reason that it's on there....
                  I would put it on and make sure it's installed on the tube in the proper position so it can filter the gas and not restrict your flow....
                • 69hemibeep
                  69hemibeep Well-Known Member
                  239
                  71
                  Jul 18, 2010
                  AZ
                  Local Time:
                  3:19 PM
                  Ive had to double up on the gaskets on the last two Ive done.
                • halifaxhops
                  50,863
                  18605
                  Jan 20, 2014
                  CENTRURAL, PA
                  Local Time:
                  6:19 PM
                  Use nos or oem usued lock rings.
                • DemonDave
                  742
                  187
                  Oct 17, 2004
                  Victoria, BC
                  Local Time:
                  3:19 PM
                  I'd rather that any gunk in the fuel system clogs the clear inline filter upstream of the mechanical pump in the engine compartment where I can easily see (and replace) it than clog a fine-mesh strainer hidden inside of the tank.
                  :thumbsup:
                • RedFish
                  23,291
                  2164
                  Sep 5, 2007
                  Local Time:
                  5:19 PM
                  In the beginning, a single screen/filter in the systems beginning was considered enough. For those systems without mechanical pumps, that never changed. Another screen/filter after the mechanical pump to protect carb was deemed necessary. Many of todays vehicles have gone back to the single screen/filter in the beginning/tank.
