Anyone have desktop dyno be willing to get me a ballpark?
Small Block Mopar Engine
  1. Cal_gecko
    Cal_gecko Citron Yella!!
    376
    54
    Nov 12, 2004
    Sacramento CA
    Local Time:
    12:57 AM
    I use a Mac, and there's no desktop dyno programs available for a Mac :(
    I'm curious if anyone out there could get me a ballpark of what my engine might be making for HP .. ?
    Engine is a remanufactured 360 - I'm assuming around 8.5:1 CR
    Stock heads
    Comp Cam XE268H cam (224 intake and 230 exhaust duration. .477 intake and .480 exhaust lift. And a 110 degree lobe seperation angle.)
    Edelbrock Performer intake manifold
    Edelbrock Performer (1407) 600 cfm carb
    Hedman headers to 2.25" exhaust with turbo mufflers
  2. RAMM
    RAMM Well-Known Member
    1,559
    1222
    Nov 22, 2010
    Ontario, Canada
    Local Time:
    3:57 AM
    No desk top dyno but I would say 320-340 hp @ 5300 rpm and 370-380 ft/lbs @ 4600 rpm. Stock heads is not enough info but this should get you close. I may be a little high though. J.Rob
    • Like Like x 1
    • Pompis
      Pompis Well-Known Member
      229
      11
      Nov 16, 2012
      Sweden
      Local Time:
      9:57 AM
      Here you have a ballpark numbers from Comp Cams dyno: 320 hp @ 5000 rpm and 368 ft/lbs @ 2000 rpm.
      • Like Like x 1
      • 273
        273 Well-Known Member
        2,847
        655
        May 14, 2012
        Ontario
        Local Time:
        3:57 AM
        My computer is screwed right now but RAMM is probably right on the money.
        • Like Like x 1
        • Cal_gecko
          376
          54
          Nov 12, 2004
          Sacramento CA
          Local Time:
          12:57 AM
          Thanks guys .. that's respectable I guess. Considering my 2012 Mustang V6 is 305hp, and it did a 13.81 @102 ... I just wanted the Dart to be close to that .. and after driving it, the Dart definitely has more torque... WAY more... and felt a bit quicker than the Mustang.. but traction will be a problem!
        • frosty_the_punk
          frosty_the_punk Well-Known Member
          697
          36
          Apr 16, 2010
          Local Time:
          5:57 PM
          A real world 310hp at the flywheel would be about the top tune for that build in my opinion.
        • 65cuda360
          65cuda360 Well-Known Member
          1,461
          27
          Aug 30, 2009
          Oklahoma
          Local Time:
          2:57 AM
          How much would that combo gain with X heads on it?
        • frosty_the_punk
          697
          36
          Apr 16, 2010
          Local Time:
          5:57 PM
          with the same valves? maybe 5-8hp
        • woody30
          woody30 woody30 FABO Gold Member
          2,396
          20
          May 13, 2012
          walton ny
          Local Time:
          3:57 AM
          Mopar Muscle mag just did a dyno test on almost exactly the same set up and got 306hp and about 360 tq.
        • 65cuda360
          1,461
          27
          Aug 30, 2009
          Oklahoma
          Local Time:
          2:57 AM
          His stock heads prolly have 1.88s, 2.02s on the Xs. Only 8 hp gain?
        • Bakerlite
          Bakerlite Well-Known Member
          1,395
          60
          Nov 12, 2007
          Local Time:
          8:57 PM
          Desktop dyno is inaccurate.
        • rumblefish360
          rumblefish360 So close, yet so far away
          35,277
          7200
          Jun 21, 2005
          New York, on a Island
          Local Time:
          3:57 AM
          Yep! And it'll only show up top the RPM scale.
          Generally speaking, yes and no, a lot depends on the exact inputs and the program also assumes a perfect running condition & optimum tune. While no program is perfect in its prediction of YOUR exact combo, it is a Ok program.
          It is best as a learning tool.
          I think RAMM has a great guess. I was thinking along the same line.
        • dustoff440
          dustoff440 Well-Known Member
          2,036
          26
          Apr 15, 2009
          central fl
          Local Time:
          3:57 AM
          see iF camquest6 AT COMPCAMS.COM WILL WORK WITH YOUR MAC
        • RustyRatRod
          RustyRatRod 30 Degrees Outta Whack FABO Gold Member
          53,008
          20851
          Jun 7, 2010
          Georgia
          Local Time:
          3:57 AM
          No, those who input into desktop dyno are inaccurate. It can be spot on with all of the correct variables. How do you expect it to be accurate without head flow numbers? I can get mine right on the money with flow sheets.
        • RustyRatRod
          53,008
          20851
          Jun 7, 2010
          Georgia
          Local Time:
          3:57 AM
          See if you can read this.
        • dustoff440
          2,036
          26
          Apr 15, 2009
          central fl
          Local Time:
          3:57 AM
          with what you stated I RAN THE NUMBERS WITH CAMQUEST..........which is close to the numbers some of the other guys ran
          310 HP @5000
          381 torque @3500
        • RCK850
          RCK850 Well-Known Member
          56
          1
          Jul 21, 2005
          Youngstown, Ohio
          Local Time:
          3:57 AM
          I got 301hp at 5000rpm and 354ft. lbs at 3500rpm. For as inaccurate as a lot of people say the program is, I've built things just like magazine articles and had my numbers come out within 5%.
          It's just like the one poster above said it's only as accurate as the information your plug in. I probably have 200 different types of cylinder heads saved with all kinds of flow numbers, just so I am as accurate as possible.
          I just use the program for fun anyways and if I was serious about half the stuff I build on it I'd be on the phone with a reputable builder for my project.
        • Cal_gecko
          376
          54
          Nov 12, 2004
          Sacramento CA
          Local Time:
          12:57 AM
          Thanks guys!! So, real world, somewhere between 300-325hp ..
        • Bakerlite
          1,395
          60
          Nov 12, 2007
          Local Time:
          8:57 PM
          Yes it's inaccurate.. Straight away I can see a carb size of 600cfm @ 3.0Hg. 4bbl carbs are rated at 1.5 Hg. So if you trying to use a 600Cfm 2bbl, then your putting a "choke" on the engine.
          8.5 :1 comp?? Really, my Briggs & Stratton lawn mower has more comp than that :)
          What size is the "small tube header" 1 1/2 ?? 1 5/8 ?? 1 3/4 ?? What sort is the muffler? Free flow? Smog type ? with lots of back pressure. That program take a lot of inputs for granted.
          I found EA pro was closer to the mark because it has a far better range of inputs.
          That program always overestimates power readings, every half decent engine builder will tell you the same. But as they say, you get what you pay for.
        • RustyRatRod
          53,008
          20851
          Jun 7, 2010
          Georgia
          Local Time:
          3:57 AM
          Until you design something better, stuff a sock in it.
        • replicaracer43
          replicaracer43 Old school member
          3,915
          2458
          Oct 10, 2008
          Local Time:
          2:57 AM
          Did you design the program your talking about? Its ok for other people to have input and opinions ya know, no need to act like a jerk. Just sayin
        • Bakerlite
          1,395
          60
          Nov 12, 2007
          Local Time:
          8:57 PM
          C'mon Rod, I'm just giving my opinion as an end user. Your comment's like saying
          " Unless you've been President of the USA, then you shouldn't comment on politics"
          Anyway, try going from a 4.030 inch bore to a 3.91 in your sim. I lost about 22 Ci but made 2 extra HP.
        • frosty_the_punk
          697
          36
          Apr 16, 2010
          Local Time:
          5:57 PM
          the user manual states the rule of thumb is that 95-105% of the exhaust valve diameter is considered a small tube header
          120-140% of exhaust valve diameter is considered as large tube header.
          It states that any mufflers simulated are high performance mufflers.
          measure the actual compression ratio of a smog era 360, if it's over 9:1 I'll eat my hat, your hat and everyone else's hat.
          I always think it's amusing that all the magazine articles tend to encourage everyone to think that an engine can be made into a 400hp+ fire breathing monster by bolting on an intake, some headers and a baby hydraulic cam, as if horsepower comes in chunks of 50 at a time with every mod.
          You may have gained 2hp peak by going to a smaller bore, but the average would have been shot to hell because of the lower displacement.
        • fishmens67
          fishmens67 Well-Known Member
          5,869
          2724
          Nov 10, 2012
          idaho
          Local Time:
          2:57 AM
          280-290 if your lucky!
        • OldmanRick
          OldmanRick Well-Known Member
          7,112
          320
          May 11, 2012
          Ladson, Sc
          Local Time:
          3:57 AM
          Lots of good discussion here Cal. My quick scan of the earlier posts by guys that know there stuff, looks like really close predictions.
          With that said.....Take her to the track :thumleft:. While paper numbers can give you a idea of power, they can also disappoint when the "real" numbers are revealed.
