Anyone have photos of....
boosted
Life Needs Air
Muscogee/Harris County GA
I need some pics of the wiring harness under the hood and the location of the fuse box under the dash on a 1967 Barracuda. I am trying to put this car back together that someone else took apart and want to put it all in the correct place the first time.
Plenty of them on Google, What is your major concern?
Someone just posted a red IIRC engine compartment photo in the last few days might have been related to headlight wiring
Accurate locations of everything.
That is deep!
Have you looked on the web at All. I have tons of pics stored but, this site has just as many or more.
I'd be happy to get you pics of my 68.....but I doubt anything is correct (factory)...!
Jeff
Found some on the net.. I guess I will gamble with them.. But cannot find a pic of the location of the fuse box...
Anyone have one of those?
Gimme a bit and I'll dig. Fusebox is located right by the ebrake handle. A large Phillips screw to hold it in place.
Dont know if these will help, random underhood shots. 67 cuda 273. Elec ign. In one pic you can see the plastic oil line from sender to oil psi gauge(set of triple gauges under dash). The green wire beside it(in grommet) is a coolant temp wire for triple gauges.
Starter relay shown also, 904 auto.
