Cope
Fusing with fire
1966 VW bug "mid engine" 2.5 STI Subaru engine and subi 6 speed trans.
Just starting mock up but it should fit and if it dont fit, I'll make it fit....
Looking for 400 HP at the crank.
I wanted to get the tube bent for the trany crossmember but dam it took forever just to get this far.
I had to cut the tub all the way to the torque tube,.cut the stingers, plate the pan to the torque tube and tie the stingers, tub and tube all back in before even starting motor mounts....
