I know there is no such thing as a dumb question but I still feel silly asking this. This question has to do with the identifying numbers found on a factory Carter AVS. Lets start with the carb number stamped on the right lower ear near the attaching bolt. I have a correct for my car (1968 cuda, big block, 4sp) #4426s. Preceding this is the date code 'E8', which I think translates as May, 1968, which would be correct for the June 17 build date of my car. Here comes the question. Turn the carb upside down. I have a four digit number that appears to be factory stamped on the primary throttle shaft boss, right side. It is '1805'. I also have another carb, a December, 1967, that has a '2667' in the same location. What is this number? Thank you for any help you can provide. Murray.
