Anyone use ESPO stock height springs? Interested in height.
Suspension, Steering and Chassis
  1. 340doc
    340doc Well-Known Member
    2,064
    536
    May 8, 2010
    Hollywood Fl
    Local Time:
    11:15 AM
    What's your experience? Did they raise the rear more than level? I'm leaning towards their stock height 6 leaf, but don't want a raised rear. Its a 70 Dart. Thanks.
  2. Tadams
    Tadams Tadams FABO Gold Member
    3,567
    1399
    Jun 13, 2008
    nc
    Local Time:
    11:15 AM
    If you order stock should be good. I ordered 1 inch plus. Does sit a little high but car is a bare skin. When reassembled it should be good. When you call talk to them. Very knowledgeable and will hook you up. Fast delivery as well
  3. 340doc
    2,064
    536
    May 8, 2010
    Hollywood Fl
    Local Time:
    11:15 AM
    Good info, thanks.
  4. hunt2elk
    hunt2elk Well-Known Member
    144
    41
    May 19, 2010
    WI
    Local Time:
    10:15 AM
    I am using there stock height springs, and wish I would have gone with a 1" drop. These pics are with a 15x7 rim and 255/60 tires. Have almost 600 miles on them, so I don't think they will settle anymore.
    • Like Like x 4
    • Thanks! Thanks! x 1
    • Plymouth 65
      Plymouth 65 Floorable Deplorable
      654
      446
      Jun 27, 2016
      Mich
      Local Time:
      11:15 AM
      I love those steelies, nice! 65'
    • rustyfish
      rustyfish Well-Known Member
      528
      314
      Sep 15, 2015
      Kansas City
      Local Time:
      10:15 AM
      I got plus 1" and am very happy with the rake I got, but I'm old school. If I do another, I might mini tub and slam it.
      • Like Like x 1
      • 1969VADart
        1969VADart FABO Gold Member FABO Gold Member
        2,091
        415
        Aug 19, 2013
        Fredericksburg, VA
        Local Time:
        11:15 AM
        Keep in my that if you are replacing tired and worn out leaf springs with the new springs you may end up with a little bit of an increase in ride height simply because the old springs sag. I ordered the stock height for my 69 Dart but the car rode a little high for me, so I installed a lower block.
        • Like Like x 1
        • 72bluNblu
          72bluNblu FABO Gold Member FABO Gold Member
          9,097
          3083
          Nov 28, 2008
          NorCal
          Local Time:
          8:15 AM
          I think @abodyjoe ran both the stock and +1" ESPO's on one of his Darts, maybe he can chime in with the pictures of the ride heights.
          I wouldn't go with anything higher than stock, and if you like where the car sits on its worn out springs you may want to consider a -1". If the front is lowered, that may be the ticket.
          • abodyjoe
            abodyjoe Well-Known Member
            19,384
            3761
            May 22, 2004
            Berlin,N.J. 08009
            Local Time:
            11:15 AM
            these are +1" espo. if i did it again i'd go stock or -1"
            • abodyjoe
              19,384
              3761
              May 22, 2004
              Berlin,N.J. 08009
              Local Time:
              11:15 AM
            • ir3333
              ir3333 Well-Known Member
              4,042
              707
              Jun 1, 2008
              ontario,canada
              Local Time:
              10:15 AM
              i purchased stock springs from Espo for my dart and it sat higher than i liked.I made new front spring mounts to lower it to stock height.
              • toolmanmike
                toolmanmike FABO Staff Staff Member FABO Gold Member
                36,186
                18328
                Jan 18, 2006
                Iowa
                Local Time:
                10:15 AM
                Not a 70 Swinger but I have stock height Espo's on my 66. Perfect!
                • 71Twister440
                  71Twister440 Well-Known Member
                  48
                  10
                  Dec 6, 2017
                  Lagrangeville
                  Local Time:
                  11:15 AM
                  I am running stock ESPO springs with a 1" aluminum lowering block(71 Duster) because I wanted lower modern look, but my car is also on 18" wheels and barely 75 miles since new springs so it haven't finished settling yet. Also I have a spring relocation kit with 3 different mounting location on the front perch and am unsure if they match a factory location. Just want you to have an accurate view of what I have compared to yours if it is factory. I am very happy with quality but if going for a lower modern look id def agree if I had to do it over id go with -1". Washed 1.jpg Washed 2.jpg Washed 3.jpg
                  • Like Like x 1
                  • Mattax
                    Mattax Just the facts, ma'am FABO Gold Member
                    5,328
                    2872
                    Feb 7, 2013
                    Phila. Pa
                    Local Time:
                    11:15 AM
                    Height of the body over the rear axle depends on the vehicle weight, the weight distribution, and to a lesser degree the front ride height setting.
                    That's why Chrysler and many different stock leaf spring packs. They also tried to account for use, building in more rate, and/or ratio for cargo or torque resistance on some.
                    To get some idea of the selection of factory replacement springs without going through the parts books, you can just skim the offerings from Stanley Spring (Harrisburg Pa) being sold here
                    Dodge Lancer Dart and Swinger Leaf Springs - Stengel Bros Inc.
                    Plymouth Valiant Leaf Springs - Stengel Bros Inc.
                    The only rear height info I've seen from the factory is at Hamtramck Historical.
                    The 1970 Hamtramck Registry "Chrysler Passenger Car Bumper Heights 1965 thru 1976" Page
                    Not really sure the intended purpose of this document as these heights were never in service manuals, possibly for final check before or after delivery to dealers. Note on page two that these specs are for fully loaded cars (5 passengers, full fuel) but does not say what options. Also the bumpers are somewhat adjustable and the body has some uh slop so this isn't quite the same as suspension service reference.
                    Chrysler set the cars up so the leaf springs are nearly flat at normal loads. This is for handling as explained in Chrysler literature such as here. That said, springs will show the effects of over a million cycles. I figure 70-90K miles is a good average for typically used vehicle (occassionally fully loaded, some bad roads, etc). Sometimes they will be fine for longer, and under real abuse, less miles than that.
                    • Like Like x 1
                    • 340doc
                      2,064
                      536
                      May 8, 2010
                      Hollywood Fl
                      Local Time:
                      11:15 AM
                      Interesting read, thanks.
                    • 340doc
                      2,064
                      536
                      May 8, 2010
                      Hollywood Fl
                      Local Time:
                      11:15 AM
                      Thanks everyone for your input. I think I'm gonna roll the dice and get the -1. I feel the 48 year old springs are pretty wore out and I like the height.
                      • Like Like x 1
                      • 1969VADart
                        2,091
                        415
                        Aug 19, 2013
                        Fredericksburg, VA
                        Local Time:
                        11:15 AM
                        Just for reference, here is a side profile of my stock height ESPO springs with a 1" lowering block. Note that the rear fender is almost down to the top of wheel with the lowering block. We also turned down the torsion bars in the front to lower the whole profile of the car.
                        • Like Like x 4
                        • Tadams
                          3,567
                          1399
                          Jun 13, 2008
                          nc
                          Local Time:
                          11:15 AM
                          When I picked up my 65 the springs were so flat. The car had shackles lifting as high as they could and the car sat low even when empty. The formula s had an extra leaf spring I believe. Good luck with your decision
                          • Like Like x 1
                          • toolmanmike
                            36,186
                            18328
                            Jan 18, 2006
                            Iowa
                            Local Time:
                            10:15 AM
                            Yes, from what I understand they did. My 66 Dart had the HD suspension option. It had 6 leaf springs originally. I ordered them from ESPO over the winter when the car was locked up in storage. The gal asked whether it had 5 or 6 leaf. I said 5 and got a stock spring pack (no 1 or 2" over). Although the springs have settled and I added tall 15" tires I think it sets just right for the look I want. 001b.JPG
                            • Like Like x 2
                            • Tadams
                              3,567
                              1399
                              Jun 13, 2008
                              nc
                              Local Time:
                              11:15 AM
                              Looks perfect. I think my 1 over will be good once I assemble everything. Without the glass and everything else in the car it sits a little high. Ill take a photo tomorrow when I have it outside
                            • MD68
                              MD68 Well-Known Member
                              87
                              51
                              Aug 15, 2016
                              Indiana
                              Local Time:
                              10:15 AM
                              Go for the -1's. I purchased their stock height springs. I've added a 1" lowering block and it's still too high for what i want. I have also done a spring relocation and have it on the top of the three holes in the bracket. I hope it settles a good bit when it hits the road later this summer.
                              • 71Twister440
                                48
                                10
                                Dec 6, 2017
                                Lagrangeville
                                Local Time:
                                11:15 AM
                                Sounds like just about what I have going on
                              • Tadams
                                3,567
                                1399
                                Jun 13, 2008
                                nc
                                Local Time:
                                11:15 AM
                                This us mine with formula s springs which are 1 over. Obviously there is no weight on the car now. Hope this helps. The old tires are 14 in on stock rims
                                • Tadams
                                  3,567
                                  1399
                                  Jun 13, 2008
                                  nc
                                  Local Time:
                                  11:15 AM
                                  Another shot
                                • KnuckleDuster
                                  KnuckleDuster Well-Known Member
                                  1,654
                                  650
                                  Nov 9, 2005
                                  Texas
                                  Local Time:
                                  11:15 AM
                                  +1" Espo with 275/60-15 15x8 rear and 225/70-14 on 14x7 front.
                                  Been in the car for 11 years but driven on about 3. They have settled by now.
                                  Not a Dart but hopefully it helps.
                                  • Like Like x 2
