As mentioned, manual choke gives you control of warm up and fast idle. I prefer the automatic choke,but in a few cases its not
Automatic at all.
If high idle is on too long, choke thermostat may need some adjusting.
If using manual, you would set it up like a choke thermostat so hi idle is at second highest step on cam,and dial in your preferred high idle.
Those cheap kits are just that-cheap. There are better cables, but come with a high price tag by comparison. Vernier control cables, pto cables. I have a couple on the wall in case i find a use for them.
Automatic at all.
