Are these small oil gally plugs in ok?
Small Block Mopar Engine
  1. C2ndLTpigeon
    C2ndLTpigeon Mopar or no Car! FABO Gold Member
    522
    125
    May 18, 2019
    Indio California
    Local Time:
    1:38 AM
    I just got done installing a freeze plug kit on my 318 block I just wanted to make sure and see if these oil Galley plugs are in correctly? If not I have an extra set but I'm just making sure in case there in wrong I don't want to have any oil issues. Thank you
  2. thesiren74
    thesiren74 Well-Known Member
    1,683
    1261
    Feb 23, 2014
    kenosha,wi
    Local Time:
    3:38 AM
    The cam thrust plate covers them.
    • Thanks! Thanks! x 1
    • Agree Agree x 1
    • RustyRatRod
      RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
      73,160
      48641
      Jun 7, 2010
      Georgia
      Local Time:
      4:38 AM
      Yes, they look fine.
      • Agree Agree x 1
      • C2ndLTpigeon
        522
        125
        May 18, 2019
        Indio California
        Local Time:
        1:38 AM
        Just want to make sure I did not drive them in to far. Better to get a second set of eyes. Thanks!
      • C2ndLTpigeon
        522
        125
        May 18, 2019
        Indio California
        Local Time:
        1:38 AM
        @RustyRatRod On a side note, your cam bearing install how to was great! Really helpful info for my install today.
      • yellow rose
        yellow rose Overnight Sensation FABO Gold Member
        28,537
        24967
        Jun 19, 2015
        Central Washington
        Local Time:
        1:38 AM
        I leave them out. They’re pretty much worthless.
        Do you mind me asking a question? Here goes.
        If the cam retaining plate covers both holes, why do the books all say to stake them in? I don’t get it. Like I said, I don’t use them. They are redundant.
        But why stake them??? They can’t get out. They only way out is through that plate and no way can you turn them either.
        That makes no sense to me.
      • C2ndLTpigeon
        522
        125
        May 18, 2019
        Indio California
        Local Time:
        1:38 AM
        I staked them as I was going along with the how to on installing core plugs, I hear what you are saying that the plate covers the holes and realized this after words. Surely there has to be a reason for them.
      • RustyRatRod
        73,160
        48641
        Jun 7, 2010
        Georgia
        Local Time:
        4:38 AM
        Thanks. I'm glad you liked it.
        • Like Like x 1
        • 70aarcuda
          70aarcuda Master Hoader of SBM FABO Gold Member
          16,339
          5025
          Jan 16, 2005
          las vegas
          Local Time:
          1:38 AM
          I put them in...they come in the kit with freeze plugs for a reason.....but do as you please...
          • Like Like x 1
          • Agree Agree x 1
          • brian6pac
            brian6pac Well-Known Member
            5,332
            3737
            Nov 15, 2016
            N.E.Ohio
            Local Time:
            4:38 AM
            I don't think a 340 ever had them, none of the old motors that I can remember had them and I have disassembled many SB mopars, mostly 73 and older.
          • RustyRatRod
            73,160
            48641
            Jun 7, 2010
            Georgia
            Local Time:
            4:38 AM
            I would endorse popping one back out and drilling a 1/16 hole in the cam thrust plate on that same side. Instant pressurized oil splattering all over the timing chain set.
            • Like Like x 1
            • Agree Agree x 1
            • dodgy
              dodgy Well-Known Member
              189
              268
              Sep 25, 2019
              Australia
              Local Time:
              6:38 PM
              The only mistake that can be made here is, If they are knocked in too far and block the oil feed hole to the mains.
              • Agree Agree x 3
