Jun 9, 2018 #1 scott657 Well-Known Member Joined Dec 26, 2016 Messages 1,003 Reaction score 589 Location Lancaster, Ca Changing filter and gasket on 904 how many quarts to drain pan and replace fluid
Jun 9, 2018 #2 Plymouth 65 I'll be in the shop Joined Jun 27, 2016 Messages 2,938 Reaction score 3,329 Location Mich I believe about 3 qts. 65'
Jun 16, 2018 #3 O oldkimmer FABO Gold Member FABO Gold Member Joined Nov 11, 2006 Messages 25,770 Reaction score 9,517 Location Kindersley, Saskatchewan, 3-4 approx. kim
Jun 16, 2018 #4 pishta I know I'm right.... Joined Oct 13, 2004 Messages 23,884 Reaction score 13,737 Location Tustin, CA Drain that convertor if you can. Most had the 1/8 NPT plug. Remember to add 2 qts, then start engine, out in N and add the rest. I poured 4qts in a fresh C4 and 2 ended up on the floor as the car wasnt running. Seems a C4 has a vent on top...?
