Thanks!!!!! I just pulled my axles and center section,8 3/4 A-body--I have the green bearing set-up. I had a little gear lube between the axle retainer and the axle seal is this normal???? Should there be none?? or does a little migrate out?? I did not have any leaking into my brake assembly at all--So am I go to go or should I change the seals out--Steve
