[SOLD] B body 8 3/4 150 dollars
chryslerfat
Monroe,Michigan
I have an 8 3/4 B body rear complete minus the center chunk. Drum to drum from and early b 44 spacing at the spring pads and 55 at the axle flanges in Monroe Michigan. I wont ship this it needs picked up. 150 and it is complete minus the pig-center chunk.
Will fit the following cars:
1965-70 b-body stock spring location
1968-76 a-body's with offset wheels and perch mods
e-body with doctor diff conversion which puts 10in wheels in the back( I am currently running 305/50R15's in the back of my 70' cuda with no problems).
Will fit many street rods from 1920's-1950's for added clearance and better maintanance.
I copied the above to help others know what it will go in.
Couple pics.
Which rear 65-67 or 68-70?
Not sure how to tell. Is there a difference in the housing? On the MyMopar site it shows 62-70 but it has the one piece axle and hub so I would think 66 and up large bolt pattern. In the pics you can see the drums and brakes. As stated in the description the carrier does not come with it so that wont make a difference in the year of the axle. I have another axle I am using the carrier in.
