B -body rear back in duster (back space)
Tires and Wheels (Mopar Hubcaps Too)
  1. dart67
    dart67 FABO Gold Member FABO Gold Member
    483
    60
    Nov 28, 2004
    NH
    Local Time:
    5:57 PM
    I have a 74 duster mini tubbed and springs moved under frame, was wondering with a 10'' rim what the back space would be,anyone have pics?
    Thanks
  2. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    10,443
    1290
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    11:57 AM
    ..........mine are 5in back space with lots of room.....74 duster with a 68 road runner diff..........kim..........i can mearure if u need me 2....
    • Like Like x 1
    • dart67
      483
      60
      Nov 28, 2004
      NH
      Local Time:
      5:57 PM
      That would be great if you could
      Thanks
    • dantegray
      dantegray Well-Known Member
      107
      1
      Jan 12, 2010
      Local Time:
      12:57 PM
    • crackedback
      crackedback FABO Gold Member FABO Gold Member
      17,998
      2130
      Aug 7, 2005
      92201
      Local Time:
      9:57 AM
      If you want the wheel centered in the wheeltub, it takes about 8.8" backspace which may be tough to find. That backspace is from rim edge (+.5" each side), not bead.
      A stock A body 8.75 rear with BBP conversion uses ~7.75" backspace 10" rim to get them under the car.
    • SRT_DSTR15
      SRT_DSTR15 Well-Known Member
      6,538
      138
      Mar 20, 2008
      San Jose
      Local Time:
      9:57 AM
      Intrestring because I wanted to go 9.5in with 6in BS.
    • kjunhemi
      kjunhemi Well-Known Member
      256
      3
      May 27, 2009
      South Louisiana
      Local Time:
      11:57 AM
      I have 10 inch wheel with 7.5 BS 295/50/15 tires on mine. The rear tires rub on the lip of the wheel well. Probably have 2-3 inches of space to the leaf spring though. B Body rear end also.
    • SRT_DSTR15
      6,538
      138
      Mar 20, 2008
      San Jose
      Local Time:
      9:57 AM
      Pics?
    • kjunhemi
      256
      3
      May 27, 2009
      South Louisiana
      Local Time:
      11:57 AM
      Here you go I will try to take some from under the car if I get a chance.
    • SRT_DSTR15
      6,538
      138
      Mar 20, 2008
      San Jose
      Local Time:
      9:57 AM
      springs moved in?
    • kjunhemi
      256
      3
      May 27, 2009
      South Louisiana
      Local Time:
      11:57 AM
      Yes spring relocation kit 3" kit to the frame rails.
    • SRT_DSTR15
      6,538
      138
      Mar 20, 2008
      San Jose
      Local Time:
      9:57 AM
      that explains it all haha, mini tub?
    • kjunhemi
      256
      3
      May 27, 2009
      South Louisiana
      Local Time:
      11:57 AM
      Yep mini tubbed
    • 72bluNblu
      72bluNblu FABO Gold Member FABO Gold Member
      9,165
      3173
      Nov 28, 2008
      NorCal
      Local Time:
      9:57 AM
      You guys should also list which year B body rear you have like Kim did. The B body rears vary in width by a few inches depending on the year, so that could make a significant difference in backspace.
      Housing widths, flange to flange:
      A BODY
      '66-'72= 52 5/8"
      B BODY
      '62-'63= 53 1/4" (And '64 Max Wedge)
      '64 = 55 5/8" (Exc. Max Wedge)
      '65-'67= 54 1/4"
      '68-'70= 54 15/16"
      '71-'74= 57 7/8"
      '71-'73 wagon= 59 7/16"
    • 72BBSwinger
      72BBSwinger Well-Known Member
      2,045
      53
      Feb 23, 2011
      nebraska
      Local Time:
      11:57 AM
      I have a 67 rear in mine with an 18x12 and 9.1 bs. A Demon/Duster could get away with less bs probably in the neighborhood of 8.25-8.50 since they don't have to tuck inside the wheel lip.
    • kjunhemi
      256
      3
      May 27, 2009
      South Louisiana
      Local Time:
      11:57 AM
      I do not know the year or vehicle it came from as it was already in the car when I purchased it.
