abdywgn
dismantler
would this set-up attached to a B-body trans fit an A-body? or is the raise in the bracket not tall enough to clear the crossmember? just curiosity...Thanks!
Thank-you all for the information. Guess it's been to long since I've moved parts around to see where mounts are located on these pieces. Just a hypothetical question if it could be done. I guess if it WAS that easy, it would have been done before. Thank-you all for taking time to explain and reply!
