[WANTED] B&M flexplate balanced for 360 OR 360 balanced converter
Cars and Mopar Parts Wanted
Thread Status:
  1. RussellSullivan
    RussellSullivan FABO Gold Member FABO Gold Member
    293
    368
    Apr 15, 2018
    East Liverpool, OH
    Local Time:
    11:55 PM
    Contact Seller
    I'm looking for a B&M flexplate, part number 10239. It's the one made for balancing a 360 with a neutral balanced converter.
    They are in backorder from B&M.
    I would also be able to use a lockup torque converter with 360 weights on it. If anyone has something available, I'd appreciate it. Thank you.
  2. lemondana
    lemondana BlackDart
    652
    407
    Dec 7, 2007
    Southeast NE
    Local Time:
    9:55 PM
    10239 is the 360-904. That is what you have-Correct? 360-727 uses a different number.
  3. RussellSullivan
    293
    368
    Apr 15, 2018
    East Liverpool, OH
    Local Time:
    11:55 PM
    Yes, that is the one I need. I have one on order from B&M but they have moved the expected ship date twice already. I'll keep it on order unless I can find one available.
  4. 67/6barracuda
    67/6barracuda FABO Gold Member FABO Gold Member
    894
    1035
    Jun 24, 2013
    Sharpsburg, GA
    Local Time:
    10:55 PM
    I have a stock lock up that came out a 91 ramcharger
  5. RussellSullivan
    293
    368
    Apr 15, 2018
    East Liverpool, OH
    Local Time:
    11:55 PM
    Inbox is full. Good usable condition?
  6. 67/6barracuda
    894
    1035
    Jun 24, 2013
    Sharpsburg, GA
    Local Time:
    10:55 PM
    I’ll send you some pictures at some point today. I don’t know anything about it. Other than it was attached to the 91 roller motor I bought.
  7. RussellSullivan
    293
    368
    Apr 15, 2018
    East Liverpool, OH
    Local Time:
    11:55 PM
    Gotcha. I appreciate it
  8. 67/6barracuda
    894
    1035
    Jun 24, 2013
    Sharpsburg, GA
    Local Time:
    10:55 PM
    Looks like that converter is a dud. I’m not sure what the previous owner did to it. Snout is worn and the mounting lug was rewelded for some reason, and the wait was mucked up too. 2A3CEA91-DCBD-4E86-85A7-08C67E49F328.jpeg F1A897F8-6563-4E90-B3FF-346D12B58E77.jpeg 58C05030-4E62-4B6E-9796-2AE4A10E86D0.jpeg 842EC5C2-0CFB-45B4-B410-4D3869A49B48.jpeg 0BD7CF8D-D5AC-494E-960E-0FD28AD173E6.jpeg 2DB7317A-4E5D-44F7-8F2F-6CCC7B9A113C.jpeg 488853F8-E31B-4CB3-8AE6-09AB72BFC428.jpeg 5A08D618-C1FC-4507-96BD-C737898AA1DF.jpeg AC750854-36EA-43D4-BCED-CA9786A8956E.jpeg
  9. RussellSullivan
    293
    368
    Apr 15, 2018
    East Liverpool, OH
    Local Time:
    11:55 PM
    That's a shame, because it was definitely a higher stall than the one I'll probably be running. I appreciate it though, thanks
  10. RussellSullivan
    293
    368
    Apr 15, 2018
    East Liverpool, OH
    Local Time:
    11:55 PM
    Just curious, as it may be worth it as a core, how much would you let it go for? Plus shipping. I could see about getting it rebuilt in the future.
  11. 67/6barracuda
    894
    1035
    Jun 24, 2013
    Sharpsburg, GA
    Local Time:
    10:55 PM
    Shipping will probably kill the deal. I’ll let it go for $40 dollars plus whatever shipping is. It’s the factory high stall with the 103/4 flex plate. I have the flex plate to I’ll give you. But it’s been modified. It looks to me like it was a neutral balance converter and someone may have welded the weight on but I’m not sure. I don’t have any history of it other than I own it. You can see how the clearances the flex plate for the weight and hole for the bolt. All the teeth on the ring gear are in good shape so it maybe a good core to start with. I might even have some flex plate bolts lying around 257ED293-6EBE-4C91-B4B5-B4233F8FC4C9.jpeg 9A4BEBD7-054D-42A4-8E45-12878F7E4460.jpeg
  12. RussellSullivan
    293
    368
    Apr 15, 2018
    East Liverpool, OH
    Local Time:
    11:55 PM
    Well, I'll see what B&M says on the 5th. That's the date they told me my flexplate would ship. If they extend it again, I'll contact you. Just trying to use the available funds to push my project forward, though it would be a decent core to stow away. I won't waste your time getting shipping quotes if I'm just gonna use a balanced flexplate. Thank you.
  13. 67/6barracuda
    894
    1035
    Jun 24, 2013
    Sharpsburg, GA
    Local Time:
    10:55 PM
    No problem I’ll hold on it. I have 3 360’s I’m working on but all 727’s no overdrives.
  14. RussellSullivan
    293
    368
    Apr 15, 2018
    East Liverpool, OH
    Local Time:
    11:55 PM
    Just to be sure, that IS a lock up converter?
  15. 67/6barracuda
    894
    1035
    Jun 24, 2013
    Sharpsburg, GA
    Local Time:
    10:55 PM
    I will verify if I can find my Tom hand transmission book I have around here somewhere
Thread Status:
