[FOR SALE] B & M Holeshot 2800/3200 Converter...................$450.00
GTX JOHN
Boulder City NV.
Here is a 10425 B & M Holeshot converter
Rated 2800 to 3200 RPM
Used about 2000 miles behind a 300 HP Mopar 360 Crate Engine and it
stalled around 3000 RPM. A big block or higher powered small block would
stall a bit higher. It was very streetable and progressively engaged. It has both
5/15 and 3/8 bolt patterns and will work with you stock Flexplate/Bolts which will save you
some money.
This converter works great but has some minor wear on the Hub that is very common
and not unusual. It sealed perfectly and did not ever leak at all for us.
It was about $950.00 from Summit Last years.
Because of the incidental wear (I did not polish it and it is just as removed =I will sell it for
$450.00
Plus $38 shipping or free Arizona So Nevada So California
