Back window rusted and leaking???
Mopar Body and Trim
  1. StevieC124
    StevieC124 Active Member
    32
    11
    Dec 13, 2018
    Wayne NJ
    Local Time:
    10:36 PM
    38437479-6929-4165-BB6E-2491A25287C7.jpeg FA0B2D82-4901-4C01-ADB1-64821944E6D4.jpeg 5CF6F306-C5D1-487C-809B-7C47185D1C32.jpeg 7BC8E0AB-4C5C-44D2-9E95-E28BC6C127C6.jpeg 94669A03-F49A-4A56-8DB8-1E6DFBF02BF9.jpeg Ok so there's after I pulled the old ugly sundried vinyl top off, I found a few holes around the back glass on my swinger and I'm a little confused on what to do here. The window leaks through the holes obviously but also around the bottom left corner of the window. I want to take out the glass, patch everything up nice, get a new seal, trim clips and then throw a vinyl top on but i'm not sure how to go about it or if I even should. At this point the trim is out but the clips are mostly bent or broken.
  2. 72Dart6pack
    72Dart6pack Well-Known Member
    3,469
    2867
    Feb 1, 2016
    Roseville Michigan
    Local Time:
    10:36 PM
    Find a parts car and start getting the sections you need.
    • Agree Agree x 1
    • RustyRatRod
      RustyRatRod Weenie idiot loser. FABO Gold Member
      58,567
      29020
      Jun 7, 2010
      Georgia
      Local Time:
      10:36 PM
      Cut the old out and weld good in.
      • Agree Agree x 4
      • zkx14
        zkx14 Duster De-ruster
        23,268
        16543
        Dec 23, 2012
        South Central PA
        Local Time:
        10:36 PM
        Pull window and wire brush everything really good to clean and see what you have. Make repairs. Then do vinyl. Put new clips on. Install glass and trim...
        • Like Like x 1
        • 72Dart6pack
          3,469
          2867
          Feb 1, 2016
          Roseville Michigan
          Local Time:
          10:36 PM
          Just like this. :)
          • Like Like x 4
          • toolmanmike
            toolmanmike FABO Staff Staff Member FABO Gold Member
            46,937
            31227
            Jan 18, 2006
            Iowa
            Local Time:
            9:36 PM
            Are you handy with this kind of stuff? Do you have a garage/shop with a wire feed welder, grinders and the like? If not you need to find help.
            • Agree Agree x 2
            • StevieC124
              32
              11
              Dec 13, 2018
              Wayne NJ
              Local Time:
              10:36 PM
              I knew I couldn’t avoid removing the glass. I don’t weld but how hard is it to take out the glass and reinstall it(assuming everything is patched up and fixed).
            • toolmanmike
              46,937
              31227
              Jan 18, 2006
              Iowa
              Local Time:
              9:36 PM
              2 man job to be safe. Easier to call the glass company. We have a couple guys in town that work at the glass company that are into cars. They will come over for a 12 box of beer and pull glass.
              • Like Like x 1
              • StevieC124
                32
                11
                Dec 13, 2018
                Wayne NJ
                Local Time:
                10:36 PM
                Ok I’ll be able to take it out(without breaking it) for a real idea of how much work it is. I’ll have to go to the local body shop and have the metal work done. Thanks for the help people.
                • Like Like x 1
                • kursplat
                  kursplat FABO Gold Member FABO Gold Member
                  2,157
                  1306
                  Aug 24, 2010
                  so cal
                  Local Time:
                  7:36 PM
                  you need a parts car. either buy a shell that has no problems in that area or better yet, find someone here parting one out and get them to cut that section out for you. you might want to gut the interior and see if your going to need something else too. a lot of work ahead, good luck
                • dartfreak75
                  dartfreak75 Restore it, Dont part it! FABO Gold Member
                  5,888
                  4036
                  Aug 10, 2011
                  Virginia
                  Local Time:
                  10:36 PM
                  I agree with this no need to cut up a parts car that is fixable without ruining another car.
                  • Agree Agree x 3
                  • MoparMike1974
                    MoparMike1974 FABO Gold Member FABO Gold Member
                    1,926
                    1271
                    Jun 16, 2017
                    Maryland
                    Local Time:
                    10:36 PM
                    That lower corner, no patch panel is available reproduction. Its part of the quarter panel. They do make the piece below it and its a good start if you have to fab one up by hand.
                    Body Components - Deck Filler Panel
                    Basically any parts car you find on the east is going to have rust there...unless it was a non vinyl top car. Always install new clips, they are dirt cheap.
                  • MoparMike1974
                    1,926
                    1271
                    Jun 16, 2017
                    Maryland
                    Local Time:
                    10:36 PM
                    Here are some pics from when I did mine. Both sides were bad on my car. I used those patch panels linked above and fabbed up the rest.
                    • Like Like x 3
                    • moparmat2000
                      moparmat2000 FABO Gold Member FABO Gold Member
                      15,286
                      4758
                      May 13, 2010
                      Grand Tetons
                      Local Time:
                      9:36 PM
                      Tape it up when done and and paint the roof. Damn vinyl tops have ruined so many of these cars. Seen people have a spray texture put on em like a rhino liner type material.
                      • Agree Agree x 1
                      • Mr. Sinister
                        Mr. Sinister Devastation Manager
                        834
                        453
                        Mar 3, 2017
                        Lenox, Mich.
                        Local Time:
                        9:36 PM
                        • Agree Agree x 1
                        • Syleng1
                          Syleng1 Karma is real and Life is short... FABO Gold Member
                          1,355
                          932
                          Jul 5, 2005
                          North Franklin, CT
                          Local Time:
                          10:36 PM
                          1) it is fixable.
                          2) dont quit yet, part of the car hobbit is getting your hands dirty and learning new things- push your limits.
                          3) YOU CAN DO THIS!
                          4) when you are done, stand back and realize what you accomplished and feel that much better about your car!
                          5)Remember to paint the roof before you install a new vinyl roof. The cars did not receive paint before the roof was applied at the factory and it s why they rotted so easily. Moisture under the vinyl just sat there and had a field day with the steel.
                        • MoparMike1974
                          1,926
                          1271
                          Jun 16, 2017
                          Maryland
                          Local Time:
                          10:36 PM
                          I agree, I had my paint guy paint and clear the roof even though it was getting a top.
