I am fixin to swap a later B body 8 3/4 rear axle into my 65 Coronet that now has the tapered 8 3/4 rear axle in it. Can I use the early rear axle backin plates on the later 8 3/4 non tapered axle housin? Thankya.
Scott, are you for real? That's killer cause then I don't have to use the backin plates I had saved for convertin the 8 3/4 in my Dart to BBP. Thank you.
