Barracuda spare tire
Early A-Body Discussions
  1. midlifecuda
    midlifecuda Well-Known Member
    95
    22
    Nov 13, 2008
    Local Time:
    4:28 PM
    B221897C-690B-4BE4-A76D-0342E524D0B3.png D98881C9-61E3-4117-8958-1A15257CAF4E.png 1DADB0C9-EAC9-480F-B395-FABCCAE1FAB3.jpeg Thought this might be helpful. I have a donut from a late model Crown Vic as a spare for my 1965 Barracuda. I chose this doughnut because of the 4 1/2 bolt pattern and that it does not protrude past the trunk floor.I needed a hold down to secure it and didn’t want to spend the money or wait for one on Ebay so I went to my Home Depot. I found this in the plumbing department. It turns out that it is held together with a 3/8 carriage bolt. It has a nice large wing nut and even a rubber washer that has a square cutout to fit the shank of the carriage bolt. It is the 3” model as there are different sizes. I bought a 5 inch carriage bolt and substituted it for the one that came with it. It cost less than $5.
    • Like Like x 6
    • JDMopar
      JDMopar Well-Known Member
      2,164
      983
      Jan 19, 2012
      Candler, NC/Myrtle Beach, SC
      Local Time:
      5:28 PM
      Good to know. Great idea on the hold down thingy! How tall is the Crown Vic spare, and does the center hole of the whell fit Mopar disc brakes?
    • toolmanmike
      toolmanmike FABO Staff Staff Member FABO Gold Member
      42,957
      26004
      Jan 18, 2006
      Iowa
      Local Time:
      4:28 PM
      Good thing you 65 has 4 1/2" bolt circle.
    • midlifecuda
      95
      22
      Nov 13, 2008
      Local Time:
      4:28 PM
      Crap, now I don’t know about the front discs! It was years ago that I got the donut and I’m sure I researched the hell out of it not to mention actually tried it. I would think that it worked as the Crown has discs but I will confirm tomorrow. I will also measure the height of the tire but I can tell you it’s about 3/4 to 1” shy of being flush.
      • Like Like x 1
      • Dana67Dart
        Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
        2,773
        1418
        Jul 16, 2017
        Northern Colorado
        Local Time:
        3:28 PM
        Looks fun too.
        I used a 14x4.5 (5x4) wheel and a Firestone f560 155R14 tire
        Firestone F560 Radial Tire | 155R14
        Fits cause the wheel is a stock 67, tire is small in dia but would get you to safety. Also if you had to, you could do a two tire swap to keep same sized on the rear if you have Trac Lok etc
      • moparmat2000
        moparmat2000 FABO Gold Member FABO Gold Member
        14,474
        4043
        May 13, 2010
        Grand Tetons
        Local Time:
        4:28 PM
        If you have the 4.5" bolt circle, the crown Victoria wheel will work no problem. The part thats tight is the center register hole in the rim fitting too snug on the mopar axles, or on the snout of a disc rotor. Easy fix, use a drum type rotary file on an air hi speed grinder and clearance that center hole a little bit till it fits.
      • RedFish
        RedFish Well-Known Member
        23,554
        2318
        Sep 5, 2007
        Local Time:
        5:28 PM
        I had the same space saver spare in my 67 fish back when I was running 5 on 4 to 5 on 4.5 wheel adapters.
      • midlifecuda
        95
        22
        Nov 13, 2008
        Local Time:
        4:28 PM
        So when I got home from work today I checked my space saver tire on the front desk’s and it fits absolutely no problem
        So I double checked my spare fitting the front discs and for whatever reason I didn’t have a problem with mine. It fit perfectly. My discs are the ‘73 and up swap.
        • Thanks! Thanks! x 1
