Sedanman
67-9 Valiant specialist
I'm selling my 276 geared BBP 8 1/4 set up with shock plates,u bolts,backing plates & drive shaft for 108 wb cars. It has 2 new outter axel tube seals,new brake lines,rubber hose & new u joints in d shaft & was blasted & primed. The gears & insides were in great shape when I took the axels out to put new seals in. This set up is for a 904 or 4spd trans with 8 1/4 in a 108" wb abody. I'm putting an 8 3/4 in my 67 Valiant as soon as my axels arrive & won't need the current rear,you will need drums,brakes & hardware,the backing plates will be bare. This is a direct bolt in for 67-73 valiant sedan,67-9 cuda,70-6 duster,73-6 dart sport with a 904 trans. The rear & shock plates are all that can be used on darts since they are 111" wb & the d shaft will be too short. $400 obo & pick up only. I will not split up. 60108 zip
