Moparvinson
I have a 1974 satellite parts car with front discs .if I use these spindles and discs, what would I need from an a body to complete the swap on my 1967 sbp dart? Thanks
Thanks for the link. I am trying to do this on the cheaper side since I have the satellite that is a parts car for my roadrunner and I wont be using any of the disc brake parts.
And did you use a body disc control arms or ball joint adapters? ThanksUsed the brakes from a 74 SSP on my 72 Demon.
11" rotors, 11" drums. Stops excellent, great pedal feel, non-power.
Only issue I had was the banjo fitting clearance on lower control arm if using pin type calipers.
There is a pin caliper that works. I dont recall the application.
I switched the brackets to sliders since I had everything new for them.
New calipers were in the $20/side range.
They have a 1974 dart sport at the pull apart yard but it is drum brakes and small bolt pattern. Would these be big ball joint control arms? I read that all after 1973 were.
