[WANTED] BBP Front Spindles and A Arms
Scottd9990
Concord NC
I am converting my 66 Barracuda to BBP 4.5" and Disk Brakes from 73. I need the upper A Arms and Spindles. Have everything else. Located Concord NC.
Thanks!!
Just go to Doctor Diff site & order it. Why screw around with used crappy stuff? Spend $25 more and get the parts already to install.
Spindles plus ball joint adapter bushings removes the need for different upper arms. If you already bought the larger upper ball joints... new correct upper arms is the best plan.
There have been a few threads here about bent upper arms. Too many times they come off of wrecked cars. In some cases those buyers had installed new bushings and ball joint before discovering the flaw. Good luck
