Hi All - Can anyone tell me what you call the foam gasket that seals between the front brake rotor splash shield and the spindle And where I can buy them? Any help would be appreciated.
Thanks!
Jeff
Yes, I use the white foam packages that electronics come in. A pen and scissors works. They are often called dust shields, though my guess is the factory used them to prevent the splash shields from making noise. Brake pad goop would probably work as well.
