Bearing Seals????????????????????????????????
Dodgenut64
MO.
Ive never put on my oun rotors before and i need a little help. Which way does the bearing seal go on? I thought Id ask before I destroyed it putting it in. Any help would be great.
Most every seal has a concave side which goes toward the grease or oil.
The pricple is the material should push the seal lip toward tighter agianst a surface. I always fill the seals cavity with grease before install rather than expect the oil or grease to get there in time to prevent burning the seal lip .
