Bench seat wire
BWDart
New Braunfels TX
Where can I get the wire that connects the seat adjusters for a 72 Dart with bench seat? Has anyone made one? If so what kind of wire did you use?
Thanks
I purchased a choke cable and just used the inner wire, got to have a wire with high tensile strength or it will stretch on you. I was lucky to find a place that sold just the inner wire. Make your bends...install, and then use needle nose pliers to make Z bend for a finale adjustment.
Last time I had to do this I used spring steel wire. It's hard to handle and hard to bend, but it's tough as nails.
Not sure the length required but consider those road side utility marking flags. May fit you need.and cheap.
