bending trunk lip -'68 barracuda
Mopar Body and Trim
  1. Dave NEO
    Dave NEO Well-Known Member
    803
    149
    Jan 6, 2017
    midwest
    Local Time:
    9:05 AM
    '68 barracuda - one side has always been a bit lifted up - creating a larger gap where trunk lid it meets the tail lite bezel. Anyone ever had this and try to give it an inward push to bend and correct/improve? 272178_2731b622fb3b_low_res (2)_LI.jpg
  2. mycuda
    mycuda FABO Gold Member FABO Gold Member
    5,314
    2110
    Feb 15, 2011
    Chicago/ Metro
    Local Time:
    10:05 AM
    Remove trim first.
    Channel locks or similar to bend down.
    Bend a little on edge of lid ,trial and error.
    Should be good.
  3. Dave NEO
    803
    149
    Jan 6, 2017
    midwest
    Local Time:
    9:05 AM
    thanks - will try it I suppose.. don't want to muck up that big trim piece though.
    more visible in this pic not just the trim - the whole trunk lid seems pulled upward. 272236_a22440f9ebec_low_res (2).jpg
  4. Mike69cuda
    Mike69cuda 63 is the new 17 FABO Gold Member
    398
    242
    Jan 2, 2018
    Overland Park Kansas
    Local Time:
    10:05 AM
    I’ve got the same issue on my 69
  5. Tooljunkie
    Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
    7,718
    6257
    Jul 22, 2017
    Manitoba
    Local Time:
    10:05 AM
    Wonder if there is a way to pull it from the inside. Or with a ratchet strap. I have pulled metal into place with my ratcheting load binder,i just fab up a hook to fit the need.
    • Like Like x 1
    • 1969383S
      1969383S FABO Gold Member FABO Gold Member
      3,850
      1295
      Jan 8, 2012
      Cumming, GA.
      Local Time:
      11:05 AM
      Do remember that these A-Bodies were enconomy cars in the line up and perfection was rare. All the trim lining up perfectly is only on very over restored cars.
    • Tooljunkie
      7,718
      6257
      Jul 22, 2017
      Manitoba
      Local Time:
      10:05 AM
      Might want to check the fit to the weatherstrip and panel its mounted to.it could be pushing it out.
      Use a sheet of paper,size of a dollar bill and close trunk on it. If it grabs the paper snugly you will need to adjust jamb the same amount.
    • Dave NEO
      803
      149
      Jan 6, 2017
      midwest
      Local Time:
      9:05 AM
      rest of trunk lines up so I don't think weatherstrip is issue but I'll check. Weather break next 2 days so I'm taking off that piece and seeing if it needs tweaking on the workbench then maybe do the trunk edge itself if it's not lining up with the tailight section. will report back.
      Economy? C,mon Gerald, I got an H price class code in my VIN, lol.
