Nov 11, 2010 #1 I intergalactica FABO Gold Member FABO Gold Member Joined Dec 16, 2006 Messages 485 Reaction score 85 Exactly what are the benefits of eccentric upper control arm bushings? How would I know if I need them? My car is a '67 cuda if it matters.
Nov 11, 2010 #2 abodyjoe Well-Known Member Joined May 22, 2004 Messages 25,883 Reaction score 16,659 Location Berlin,N.J. 08009 some install them to gain more caster for handeling. some cars are bent and need them to get the alignment to stock specs..
Nov 11, 2010 #3 caferacerx BAND MEMBER Joined Aug 15, 2009 Messages 3,593 Reaction score 57 Location philly PA they increase the range of adjustment for the upper control arm, the factory alignment specks were designed for bias ply tires not radials, so on some car's they help achieve an alignment setting preferred for modern radial tires
