Bent upper control arm bad or okay?
autumn ash
Texas
I was pressing in a new bushing and it wasnt lined up right with the socket i was using and it bent it a small amount. Its not in the way of anything and its just the small spot. Is it fine?
i'd test fit it to the car with nothing attached to it and run thru the range of motion just to be sure nothing sticks up anywhere. other than that, ship it.
As long as the bushings are in a straight line you'll be fine. You can eyeball straightness by looking through from each bushing with one eye. You'll know if it's straight or not.
