Dartsun
Mopar Dude
Where did you get your plug wire valve cover holders from? Engine looks great Dustin
Yep that's were i live!Pretty sure I've seen your car around Bville a couple of times. I never was able to get a good look.
I would drive it like it is. If it is working, don't mess with it. Being 19, limited $ and probably mechanical xperience...... The performance increase for $$$ spent wouldn't make a great difference. Save you $$ if you like the car and find a 360 down the road. Enjoy it like it is- drive itRight now all have done (Performance wise) is i got a dual exhaust with an X pipe in it and some off brand Magnaflows! i am in a debate on if i want to keep this car more stock just for cruising around and getting a project car and put a big motor in or if i want to dump it all into this.
those are 273 commando valve covers....they have those holders right on the valve covers from the factoryWhere did you get your plug wire valve cover holders from? Engine looks great Dustin
The valve covers turned out great. I was curious of the plastic clips the hold the plug wires to the covers. I've found some before but they were for skinny wires. Thanks DustinYep like bbrroowwnn said, the factory used this type of valve cover on the 273 Commando engines. Not sure how hard they are to come by. I redid my covers by removing the old paint and using "wrinkle paint", then baking them in my wife's oven (she wasn't home at the time!). It's been about two years and they still look pretty good.
Thanks!! I was in a hurry to get the motor in so I used Hemi Orange paint. Next time I pull it I'm going to go with something closer to the factory block color...I've heard Chrysler is close. The engine bay is the original paint...complete with a run on the firewall.
there was an old D64 intake WITH two carbs on the local CL (local to me, not you) a while ago for 350
that would have been sweet
nice ride though
She is a little dirty right now!
Well the guy I got it from put disk brakes on the front and power steering! I will be sure to put up more!Not too dirty!! Looks good.
I really need to pull my power steering pump and paint it and the bracket. My alternator could use some cleaning up also. Did you add the dual Master Cylinder? I replaced my single pot about a year ago.
Let's see some more of that Coronet!! We love car **** over here on FABO!!
Stay far away from this intake, it was junk and made no power above 4000 rpm. Use a Holley street dominator, they are almost identical to a 273 HiPo manifold and they are cheap.Anyone have an opinion on an edelbrock sp2p. Narrow runners might be well suited to the smaller 273. Thoughts?
EDIT: This thread has some opinions on it.
273/318 Edelbrock SP2P Intake Manifold
What is the advantage of a vertical filter??Nice car. Whether you change carbs or not, You really should relocate the fuel filter to a vertical position ( see 73 and up tube routing design ) and please use a metal filter.
