Best disk brake kit for 65 Dart?
Brakes for your Classic Mopar
  1. Arizona
    Arizona Former Yooper, always a MoPar fan.
    61
    15
    Aug 16, 2017
    Gilbert, AZ
    Local Time:
    9:51 AM
    Thanks to a change in direction I made yesterday with my project, I have decided that I need to change to disk brakes - and of course need recommendations. Since I won't have the stock engine* in it anymore I feel the need to go to disk brakes. Questions -
    Would you do front and rear or just front? Does it matter much if you do the conversion with the engine out? Would it be a lot easier or not really?
    Which kit would you get? Price is not necessarily a problem but I don't want to get racing quality 'cause I ain't gonna race like that.
    Did you run into problems with the kits - wrong/missing parts or anything?
    *Jake Burt is sort of responsible for my change in direction. I posted asking for advice on how to break the heads free on my 273 2BBL so I could get it apart and get the heads rebuilt. Jake emailed me saying he had a Commando engine for sale. Long story short, it is now in my garage waiting to get in my 65 Dart. It is a fabulous engine built above Commando specs - 40 over, hydraulic lifters, and all new parts. I think I will call it the Commando+. It runs flawlessly and will be perfect for the Dart. Jake was great to buy from. His price on it was more than fair and he also gave me a few extra 65 parts he had - some of which he will now get back, like the brake shoes/pads. Thanks Jake!
    [​IMG]
    Thanks for your help with the disks.
    Jim
  2. A833
    A833 Active Member
    30
    32
    Oct 21, 2016
    Brookhaven, NY
    Local Time:
    12:51 PM
    I used the disc setup from a 73-76 Duster ect. Used all from the lower control arm up. Use the big ball joints also and the one piece rotors. Bolts right in. Dump that single master cylinder, go with a dual and plumb in an adjustable proportioning valve in the line for the rear brakes and you're good to go. I also up graded to an 8 3/4 rear and swapped in big bolt pattern axles (5 on 4.5" to match new front rotors) and 11"x 2.5" drum set up from an E body. Discs all around is the best but in a early A body like ours, drums in the rear are plenty. Post some pics of you're project for us early A fans.
    • Like Like x 1
    • pauly
      pauly MOPAR or no car! FABO Gold Member
      1,636
      362
      Nov 1, 2012
      Holton, Michigan
      Local Time:
      11:51 AM
      Depends on if you want to run big bolt pattern wheels or small bolt pattern.
    • 65 Dartman
      65 Dartman FABO Gold Member FABO Gold Member
      9,728
      1667
      Sep 24, 2006
      Strasburg, VA
      Local Time:
      12:51 PM
      I will be also going with the 73-76 LBP disc setup less the lower control arm. I will be swapping the calipers to the rear as I will also be using a Hellwig early A sway bar. Going with a 73-76 disc master cylinder. The rear will be an 8.75 with LBP axles and a 94-04 Mustang based disc setup. Engine will be a 66 Commando with hydraulic lifters.
    • stroked340
      stroked340 Well-Known Member
      4,216
      1121
      Jun 14, 2014
      mass.
      Local Time:
      12:51 PM
      Wilwood..bolted right on no problems better lighter and nicer looking then any of that old been around forever rusty factory crap:eek::eek:
      • Like Like x 1
      • Disagree Disagree x 1
      • memike
        memike Super Moderator Staff Member FABO Gold Member
        48,914
        8940
        Jan 8, 2006
        on the hill
        Local Time:
        11:51 AM
        73-76 LBP disc setup, bolted right on and any part can be found at any auto parts or salvage yard, very happy.
        • Like Like x 1
        • Agree Agree x 1
        • Arizona
          61
          15
          Aug 16, 2017
          Gilbert, AZ
          Local Time:
          9:51 AM
          There are lots in my photo garage, not sure how to help you find it... more will be coming soon.
        • A833
          A833 Active Member
          30
          32
          Oct 21, 2016
          Brookhaven, NY
          Local Time:
          12:51 PM
          Here are the pics I took after install, Got all the calipers, hoses, wheel bearings and pads at my local auto parts store. By the way I went with silicone brake fluid also.
          • Like Like x 1
          • BillGrissom
            BillGrissom Well-Known Member
            7,212
            325
            May 10, 2009
            Sacramento
            Local Time:
            9:51 AM
            The "best kit" might be the factory 1964-72 Kelsey-Hayes front disks, which were also used on Mustangs, but very rare. I doubt you can find 1973+ front disks in "any junkyard" today, as memike said. It is rare to find any pre-1980 Mopar car around northern CA today and most are quickly stripped in a few days. But, you can buy the 1973+ kit new for ~$500 from many sellers. Wilwood is ~$750, then you are locked to them for expensive spare parts. Rear disks are mainly for show. You may find you need to change your rear-end to handle a beefed-up engine. If so, some people use a Ford Explorer 8.8 rear (cut down), which gives your rear disks gratis.
            • Thanks! Thanks! x 1
            • billccm
              billccm Well-Known Member
              84
              50
              May 13, 2018
              Tucson
              Local Time:
              9:51 AM
              Before you buy at least consider Dr Diff. Perhaps send a email for advice from the doctor?
              • Agree Agree x 1
              • easyrider
                easyrider 65 droptop
                440
                182
                Aug 21, 2011
                Crystal Springs, MS
                Local Time:
                11:51 AM
                The front disc setup from a 1985 Dodge Diplomat will work. They are cheep and can still be found in junk yards. You'll need to buy an adapter from Dr. Diff for the top Ball joint. Use the steering arm from your car and you're good to go.
                • Agree Agree x 1
                • toolmanmike
                  toolmanmike FABO Staff Staff Member FABO Gold Member
                  36,151
                  18294
                  Jan 18, 2006
                  Iowa
                  Local Time:
                  11:51 AM
                  Best, cheapest, easiest to install, easiest to find repair parts for. There are many different answers.
                • Commando66
                  Commando66 She's a beaut Clark!
                  1,754
                  194
                  Dec 2, 2007
                  Gig Harbor, WA
                  Local Time:
                  9:51 AM
                  There are a few questions you should answer first. Do you want to stay with small bolt pattern(SBP)? Move up to large bolt pattern(LBP)? Make any suspension upgrades at the same time? Scarebird has some pretty good options Mopar
                  You wouldn't have to tear into your front suspension either.
                  • Agree Agree x 2
                  • easyrider
                    440
                    182
                    Aug 21, 2011
                    Crystal Springs, MS
                    Local Time:
                    11:51 AM
                    I tried the Scarebird route. Wasn't happy at all. Was so disappointed that I ALMOST sold my car. Glad I didn't.
                    • Commando66
                      1,754
                      194
                      Dec 2, 2007
                      Gig Harbor, WA
                      Local Time:
                      9:51 AM
                      What went wrong? I don't have any personal experience, but a couple friends have used them on an A100 and a Sweptline.
                    • Arizona
                      61
                      15
                      Aug 16, 2017
                      Gilbert, AZ
                      Local Time:
                      9:51 AM
                      I am not going to upgrade anything more than the brakes. It is a 273 car so it is built to handle what I have, and I am not going to be driving it anywhere near that hard. I have done enough damage to my cars in the past to know what it takes to break a Mopar. I did manage to destroy the rear end in my '68 Barracuda doing neutral drops.... :(
                    • Arizona
                      61
                      15
                      Aug 16, 2017
                      Gilbert, AZ
                      Local Time:
                      9:51 AM
                      True. I just want disc in the front for safety. Best to me means mid-range on all things if that is possible. Not racing quality. Mid-price, not the hardest to work on or get parts for.
                    • easyrider
                      440
                      182
                      Aug 21, 2011
                      Crystal Springs, MS
                      Local Time:
                      11:51 AM
                      I had my hubs re-drilled for the 5 on 4-1/2 bolt pattern. The wheels with the bigger bolt pattern have a larger center hole. I tried using hub centric rings, but that didn't work very well. I still have all that stuff if someone wants it. $100. plus the ride and its yours.
                      • GoDartGo
                        GoDartGo thread killer un-member
                        713
                        53
                        Sep 1, 2005
                        Athens Michigan
                        Local Time:
                        11:51 AM
                        I have the Scarebird set up, no problems.
                        • jas0162
                          jas0162 Well-Known Member
                          295
                          134
                          Apr 23, 2014
                          kansas
                          Local Time:
                          11:51 AM
                          I have the Scarebird stuff on my car and it works great. I like it that you can get all the replacement parts at any parts store, and I used the 9 inch drum spindles I already had. It is far from the last word in high performance but it is a huge improvement over the stock drums.
                          • easyrider
                            440
                            182
                            Aug 21, 2011
                            Crystal Springs, MS
                            Local Time:
                            11:51 AM
                            Spindles, hubs, calipers, rotors, pads and Scarebird brackets for both sides. $100 plus the trip.
                            • D_Matheson
                              D_Matheson Matheson Sports Car
                              18
                              13
                              Feb 13, 2018
                              Jonesborough, TN
                              Local Time:
                              12:51 PM
                              I recently asked this question myself, but I couldn't find a compromise between performance, price, wheel fitment, and spare part affordability. I've decided to go my own way and build my own. MSC_Rally Cuda_Assy6.PNG MSC_Rally Cuda_ExplView1.PNG
                              • Arizona
                                61
                                15
                                Aug 16, 2017
                                Gilbert, AZ
                                Local Time:
                                9:51 AM
                                This looks like the best bet to me. I was planning on master/porp valve anyway and this includes them. Have any of you used kits or parts from this company? Thanks, Jim
                                MDC66SD
                              • GoDartGo
                                713
                                53
                                Sep 1, 2005
                                Athens Michigan
                                Local Time:
                                11:51 AM
                                by the scale of the drawing, that spacer looks to be 1/2" or more thick.
                              • Jimacuda
                                Jimacuda Well-Known Member
                                1,301
                                314
                                Nov 10, 2006
                                Phoenix AZ
                                Local Time:
                                9:51 AM
                                I should have an FMJ disc set-up out in the shop if you'd like to check it out.
                                Easy to find replacement parts.
                                I'm at base of S. Mountain in Phx.
