Best low profile 383 dual plane aluminum intake?
Mopar Performance Issues
  1. LovetheA's
    LovetheA's FABO Gold Member FABO Gold Member
    642
    77
    Aug 26, 2010
    Danbury, CT
    Local Time:
    5:05 AM
    Im on a tight budget after all the upgrades I recently did to my 67 Dart. Therefore I thought what performance upgrades could I apply to my 67 383 formula s at minimal cost. The original 383 engine as far as I know has never been apart and has great compression and uses very little oil. I was thinking I could swap out the factory 516 heads for the 915 heads I took off my dart. Then upgrade to an aftermarket aluminum dual plane low profile intake. I was thinking top that off with the carter 750 cfm that came on the 67 manual trans 440 and transplant my tti headers I had laying around. I think that may be good for about 30-40 horse. What does the peanut gallery think? If that seems like a good move then I would need to purchase a good performance intake for this application and preferably a low profile dual plane so I could put the original air cleaner on and fit under the hood.
  2. LovetheA's
    642
    77
    Aug 26, 2010
    Danbury, CT
    Local Time:
    5:05 AM
    Something I just thought of. The 915 heads most likely were decked before they were put on my dart and I believe the 516’s have never been off the Barracuda. Would it be wise to run thicker gaskets so I don’t have compression issues moving to the 915’s? I still would like to be able to run 93 octane.
  3. RustyRatRod
    RustyRatRod 30 Degrees Outta Whack FABO Gold Member
    48,055
    13427
    Jun 7, 2010
    Georgia
    Local Time:
    5:05 AM
    The old Offenhauser 360* intake for the B engine was a great intake and very low profile.
    • Thanks! Thanks! x 1
    • Agree Agree x 1
    • sabre67
      sabre67 FABO Gold Member FABO Gold Member
      504
      113
      Jan 9, 2015
      British Columbia,Canada
      Local Time:
      2:05 AM
      :popcorn:watching
    • Bobzilla
      Bobzilla Well-Known Member
      434
      281
      Aug 10, 2017
      Livonia, Michigan
      Local Time:
      5:05 AM
      Does your 383 already have a factory four barrel intake?
      I am not sure there would be a good return on investment switching 516 heads to 915 heads if both have the same small exhaust valves, and switching factory cast iron four barrel intake for an older design aluminum version, since you mention the tight budget.
      Of course you already have the heads, so it won't be too expensive to try it.
      For your compression question, just wait to buy gaskets until you get the old heads off so you can measure the volume above the piston and calculate the compression ratio accurately, then select the head gaskets you need.
      • Agree Agree x 1
      • LovetheA's
        642
        77
        Aug 26, 2010
        Danbury, CT
        Local Time:
        5:05 AM
        Thanks Bobzilla for the advice. I should provide a little more background on the swap I’m planning. The 915 heads came off of my 67 Dart and they aren’t stock. They have the enlarged intake and exhaust valves and upgraded springs. Im also thinking about a mild port job for $400.00 bucks by my machinist. I’m going to put on 1.6 ratio aftermarket shaft rockers from Mike at B3 racing. Not real high end jobs but affordable middle of the road. Then swap out the terrible cast iron dual plane 67 383 intake on my Barracuda and replace with a dual plane low profile aluminum job. Then top it off with my 67 440 750 cfm carter. I’m thinking that should be good for some ponies. Your thoughts?
        • Agree Agree x 1
        • pishta
          pishta I know I'm right....
          13,721
          3449
          Oct 13, 2004
          Tustin, CA
          Local Time:
          2:05 AM
          Id call the Offy 360 a smashed single plane. There is no plenum separation between the carb sides. The 360 was the catch-phrase that meant that the cylinders were pulling "360 degrees" (all the time) instead of the '180' design of a dual plane. The Weiand Action Plus is a smoother runner version of the Performer 383 and is .2 shorter to carb pad.
        • LovetheA's
          642
          77
          Aug 26, 2010
          Danbury, CT
          Local Time:
          5:05 AM
          Thank you Pishta. I welcome at the feedback and advice. I absolutely love this website as a resource.
          Carl
        • 66fs
          66fs Well-Known Member
          3,676
          638
          Sep 9, 2009
          Greenwood, South Carolina
          Local Time:
          5:05 AM
          I would think 30-40 HP easy. The 440 AVS is a great carb. I would think that the Torker, the vintage Edelbrock dual plane with the Chrysler number, Offenhouser, or the Holley Street Dominator. Pay attention to the choke set up , or lack of one. Definitely run the 915 heads, there should be little change in chamber volume, but it never hurts to measure them. I always run Fel-Pro head gaskets. All big block Darts and Barracudas were 4 barrel carbs.
        • oldkimmer
          oldkimmer Well-Known Member
          9,754
          976
          Nov 11, 2006
          Kindersley, Saskatchewan,
          Local Time:
          4:05 AM
          Even just a 68 up intake is way better then the 67. Whatever u do don’t buy a regular eddy performer. Kim
          • Agree Agree x 1
          • LovetheA's
            642
            77
            Aug 26, 2010
            Danbury, CT
            Local Time:
            5:05 AM
            Kim
            Why what’s wrong with the edelbrock performer rpm intake? That intake gets great reviews. I was leaning towards that if I could get it under the hood without any clearance issues. What should I do because my 1967 750 cfm carter has a manual choke assembly and I don’t think the aftermarket intakes can accommodate that. Can I just pull off the choke set up? Does any after mkt intake have provisions for my manual choke set up?
            Carl
          • oldkimmer
            9,754
            976
            Nov 11, 2006
            Local Time:
            4:05 AM
            Nothing wrong with the performer rpm, it’s a great intake. the regular performer is basically a door stop. What number is on the carb. It won’t be a 750 more like 500 to 625 cfm if this is a factory carb. Do u use the choke now, if not u could take it off but it is recommended to have a choke as u have much easier cold starts. Is the choke run by a cable or from the choke well in the intake. Kim
          • Abodybomber
            Abodybomber Breaking street machines , since 1983.....:) Legendary Member
            32,085
            10479
            May 21, 2011
            Arroyo grande ca
            Local Time:
            2:05 AM
            8008 Weiand Steath ,if you have room, underhood...
            Another, decent choice, Run , the smaller carb ....
          • LovetheA's
            642
            77
            Aug 26, 2010
            Danbury, CT
            Local Time:
            5:05 AM
            Kim
            I’m leaning toward the edelbrock performer rpm. I have the choke which sits in the manifold well and works off the engine heat. The carb I have is the 4 speed factory hi-po carter carb that came on the 67 hi performance 440. What cfm was that?
          • LovetheA's
            642
            77
            Aug 26, 2010
            Danbury, CT
            Local Time:
            5:05 AM
            Abodybomber
            Will the Weiand 8008 stealth work with the carb and still fit under a stock hood? That is a big concern.
          • RustyRatRod
            48,055
            13427
            Jun 7, 2010
            Georgia
            Local Time:
            5:05 AM
          • 72bluNblu
            72bluNblu FABO Gold Member FABO Gold Member
            9,040
            3015
            Nov 28, 2008
            NorCal
            Local Time:
            2:05 AM
            • Like Like x 1
            • Agree Agree x 1
            • skrews
              skrews Well-Known Member
              1,226
              571
              Jul 20, 2012
              Washington state
              Local Time:
              2:05 AM
              Street Dominator
            • LocuMob
              LocuMob Fluid Technician
              1,431
              598
              Oct 30, 2013
              Southern Mn
              Local Time:
              4:05 AM
              What's the disadvantage with the 67 down intake?
            • oldkimmer
              9,754
              976
              Nov 11, 2006
              Local Time:
              4:05 AM
              It is very low profile and doesn’t flow nearly as good. If u compare them side by side u will see a huge difference. Kim
              • Agree Agree x 1
              • LocuMob
                1,431
                598
                Oct 30, 2013
                Southern Mn
                Local Time:
                4:05 AM
                I was wanting to out the correct numbers intake in my 66, but it's not necessary. How did they rate the different years the same HP? I'm so used to throwing on aluminum intakes I never compared the stock units.
              • 66fs
                3,676
                638
                Sep 9, 2009
                Local Time:
                5:05 AM
                68 is the start of the good ones. 72 with the TQ is another really good one.
                • oldkimmer
                  9,754
                  976
                  Nov 11, 2006
                  Local Time:
                  4:05 AM
                  I believe factory 440 hp AVS carbs were about 625-650 cfm. Kim
                • LovetheA's
                  642
                  77
                  Aug 26, 2010
                  Danbury, CT
                  Local Time:
                  5:05 AM
                  Thank you for all the responses so far.
                • rumblefish360
                  rumblefish360 so close yet so far away
                  33,457
                  5526
                  Jun 21, 2005
                  New York, on a Island
                  Local Time:
                  5:05 AM
                  Depends on the specific engine model as the HP engines got the 750 AVS. Mostly the large people mover cars, wagons and such for the 630 AVS.
                  (630 as per the old Carter/Federal Mougal phone lines.)
                  • Agree Agree x 1
