Best manual transmission for 900 hp
Manual Transmission & Clutch Discussions
  1. LO23M8B
    LO23M8B Well-Known Member
    1,435
    721
    Jan 30, 2019
    Michigan
    Local Time:
    5:02 AM
    Hi everyone. What would be a good manual trans. for a 900 hp. 3400 lb car with some cost in mind? Thanks.
  2. toolmanmike
    toolmanmike Moderator Staff Member FABO Gold Member
    62,401
    51607
    Jan 18, 2006
    Iowa
    Local Time:
    7:02 AM
    Probably a Liberty or Lenco. Drag race only I presume?
  3. rumblefish360
    rumblefish360 I have escaped the evil Empire State! FABO Gold Member
    41,707
    13953
    Jun 21, 2005
    Florida
    Local Time:
    8:02 AM
    How does a Jericho fit into this equation?
    • Like Like x 2
    • Professor Fate
      Professor Fate Push the button, Max...
      2,469
      3348
      Jan 13, 2020
      Wisconsin
      Local Time:
      7:02 AM
      Is the old Doug Nash 5sp. a viable option anymore? I thought I read someone bought the rights and is still producing them... Liberty, maybe?
      Don't forget the Borg T56 & TR6060
    • toolmanmike
      62,401
      51607
      Jan 18, 2006
      Iowa
      Local Time:
      7:02 AM
      Another good one.
    • rumblefish360
      41,707
      13953
      Jun 21, 2005
      Florida
      Local Time:
      8:02 AM
      Thanks... exactly.... :thumbsup:
    • rumblefish360
      41,707
      13953
      Jun 21, 2005
      Florida
      Local Time:
      8:02 AM
      IDK about the Nash. I don’t think you can get them new but it is worth a check.
      Your next two are OOTB 900HP capable?
      • Agree Agree x 1
      • Professor Fate
        2,469
        3348
        Jan 13, 2020
        Wisconsin
        Local Time:
        7:02 AM
        I think you got me- the only specs I found in a quick search are the 645hp/600ft.lbs. in the '17 Viper. I thought they were higher...
      • dano
        dano Evil Handy Man
        4,073
        1913
        Aug 22, 2005
        Gresham, Oregon
        Local Time:
        5:02 AM
        How much torque, traction, and how grippy is the clutch? A 300ft/lbs T5 (for example) would last it just depends on the use, set up and traction.
        • Disagree Disagree x 1
        • rumblefish360
          41,707
          13953
          Jun 21, 2005
          Florida
          Local Time:
          8:02 AM
          It might hold more power. I just don’t know myself.
        • LO23M8B
          1,435
          721
          Jan 30, 2019
          Michigan
          Local Time:
          5:02 AM
          Drag race only. I would probably start with the calvert set up and maybe try some drag radials if they don't work out 14 x 32 slicks. Also eventually go to a 4 link. How much are we talking about for a Liberty set up? Used maybe.
        • LO23M8B
          1,435
          721
          Jan 30, 2019
          Michigan
          Local Time:
          5:02 AM
          Also how about a doug nash crash box?
        • RustyRatRod
          RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
          79,466
          57904
          Jun 7, 2010
          Georgia
          Local Time:
          8:02 AM
          Yes, Richmond bought Nash out some time ago. Their five speed is the updated Nash version.
          • Thanks! Thanks! x 1
          • SSG_Karg
            SSG_Karg Heeeeeres Johnny!
            1,510
            1489
            Feb 24, 2010
            In the pits
            Local Time:
            8:02 AM
            Lenco, Liberty, or Jerico. Probably looking at $6-$8k for trans and slipper clutch and all the accoutrements. Being cool costs $$$$.
            • Agree Agree x 2
            • Like Like x 1
            • yellow rose
              yellow rose Overnight Sensation
              28,501
              25174
              Jun 19, 2015
              Central Washington
              Local Time:
              5:02 AM
              G-Force.
              • Agree Agree x 1
              • LO23M8B
                1,435
                721
                Jan 30, 2019
                Michigan
                Local Time:
                5:02 AM
                Ya I know. It's a bitch. But someone (me ?) has got to do it.
                • Like Like x 1
                • yellow rose
                  28,501
                  25174
                  Jun 19, 2015
                  Central Washington
                  Local Time:
                  5:02 AM
                  The Lenco is damn long, especially if it’s a 5 speed (it should be a 5 speed) and it takes more power to run all those clutch packs.
                  The Jerico is only available with 4 gears AFAIK. Again, I can’t think of a reason to run 4 gears when you can use 5. 5 gears is quicker every time.
                  That leaves the Liberty and the G force. The Liberty is a dual cluster gear box, and the G force uses a single cluster with a support to keep the main shaft from moving.
                  Both can be had with 5 gears.
                • boilermaker
                  boilermaker Well-Known Member
                  68
                  14
                  May 10, 2013
                  toronto
                  Local Time:
                  8:02 AM
                  I have a buddy with a Doug Nash in a 9 second fox body mustang. He is parting out the car. The trans also has a vertigate shifter. Its up in Toronto
                • LO23M8B
                  1,435
                  721
                  Jan 30, 2019
                  Michigan
                  Local Time:
                  5:02 AM
                  Shell also 4 sale?
                  • Agree Agree x 1
                  • RustyRatRod
                    79,466
                    57904
                    Jun 7, 2010
                    Georgia
                    Local Time:
                    8:02 AM
                    Probably the best and most cost effective transmission is a Turbo 400 with a manual valve body. You can build one probably for less than half the cost of anything being talked about here. CHEAP and STRONG.
                  • pishta
                    pishta I know I'm right....
                    21,388
                    10777
                    Oct 13, 2004
                    Tustin, CA
                    Local Time:
                    5:02 AM
                    • Like Like x 1
                    • boilermaker
                      68
                      14
                      May 10, 2013
                      toronto
                      Local Time:
                      8:02 AM
                      Yes.
                      Roof has a sunroof , not so good around sunroof .
                      Floor is solid.
                    • j par
                      j par Well-hung Member
                      28,319
                      16223
                      Jul 2, 2014
                      Portland Oregon
                      Local Time:
                      5:02 AM
                      900 hp...
                      Manual trans...
                      Drag racing...
                      Is a ridiculous conversation to have with a thrifty budget...
                      • Agree Agree x 1
                      • pishta
                        21,388
                        10777
                        Oct 13, 2004
                        Tustin, CA
                        Local Time:
                        5:02 AM
                        :rolleyes:
                        • j par
                          28,319
                          16223
                          Jul 2, 2014
                          Portland Oregon
                          Local Time:
                          5:02 AM
                          Miss quote... :rolleyes:...
