Best of the cheap rockers?
myasylum
Las Vegas, NV
I know that their isn't such a thing as "good, and cheap", but how about the best for the price? I have a LA 360.
I need to get my car running correctly, and my best option is to get adjustable rockers. As far as cheap goes these appear to be my options...
273 Adjustable rockers, but since I have aftermarket Comp Springs with a 1.260 in. Outside Diameter, I hear that grinding might be required to get these rockers to fit correctly. Will that weaken these rockers?
Second, Crane Ductile Iron Rocker arms. These are about $300.00 new, but used if I look around a bit I can find for a fairly cheap price.
Then Third... I found these...
http://cgi.ebay.com/ebaymotors/ws/e..._trkparms=algo=LVI&its=I&otn=2&category=33624
I have heard that ProComp suck, but these are steel, and not aluminum. I though for $160.00 MAYBE they would be worth a shot.
Does anyone have any other suggestions, or thoughts about which one you would chose out of the three?
Thanks much!
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=260579982493&ssPageName=STRK:MEWAX:IT
pro comp suck...you heard...
ran a set of pro comp aluminum rockers on 340 bracket motor with MP 557 cam for two years until i change from 1.5 to 1.6....never had a problem.....
those you linked to probably would work just fine ....
IDK about them ethier. I have not used them nor know anybody personnally that has. There made of steel? I think it would hold. Otherwise, the Cranes are next cheapest followed by ethier Huges rockers or Comp Cams. Both are price around the $400+ mark.
What about old Manley adustables?
