Best Penetrant to Remove Differential U-Bolts?
Shop, Garage and Tools
  1. missing linc
    missing linc Loose nut behind the wheel FABO Gold Member
    1,345
    1901
    Feb 17, 2019
    Southern Alberta Canada
    Local Time:
    3:39 AM
    Be sure to measure them first, I made that mistake once or twice.
    • Agree Agree x 2
    • RustyRatRod
      RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
      60,008
      31141
      Jun 7, 2010
      Georgia
      Local Time:
      5:39 AM
      I don't disagree. Plus, you are not supposed to reuse those U-bolts. If they are tough to get off, I throw them away. If they break loose easily, I will reuse them......but again, they are supposed to be a one time use.
      • Agree Agree x 3
      • billccm
        billccm Well-Known Member
        121
        88
        May 13, 2018
        Tucson
        Local Time:
        2:39 AM
        Mancini has the correct U Bolts.
        • Agree Agree x 1
        • Kern Dog
          Kern Dog Well-Known Member
          4,125
          5540
          May 23, 2010
          Granite bay CA
          Local Time:
          2:39 AM
          Screw that.
          I reuse them all the time. Stuff over here doesn't rust and break when you work on it.
          • Agree Agree x 1
          • 1969383S
            1969383S FABO Gold Member FABO Gold Member
            5,485
            2539
            Jan 8, 2012
            Cumming, GA.
            Local Time:
            5:39 AM
            like said!
            use what you like but give it some time to work. You can't reduce 50+ years of crude in 10 minutes!
          • jomoper
            jomoper Mope or Nope
            2,994
            187
            Aug 18, 2006
            NorCal.S.F.bay area
            Local Time:
            2:39 AM
            Of all the stuff I've used PB blaster has always worked best. Except every time I use it My sense of smell is messed up for at least a day.
          • MoparMike1974
            MoparMike1974 FABO Gold Member FABO Gold Member
            2,192
            1519
            Jun 16, 2017
            Maryland
            Local Time:
            5:39 AM
            I cant stand the smell of PB blaster. One drop gets on you and you smell it for a week.
            Kroil is the best, hands down.
            • Agree Agree x 2
            • rustycowll69
              rustycowll69 Well-Known Member
              2,165
              969
              Feb 19, 2016
              Pacific northwest
              Local Time:
              2:39 AM
              I agree. Personally, I prefer Mopar Heater Control Solvent. It was made for heat risers, I think, but it'll work on anything rusty. Heat was mentioned, and that can help. I'd also suggest an impact gun w/ 6pt impact socket, but like the quoted post, work the nut gradually back and forth carefully. Be patient. It is usually worth trying to save the factory u-bolts, because aftermarket bolts are not flattened at the u-bend and are not friendly to the housing tube like the oem bolts.
            • lemondana
              lemondana BlackDart
              395
              198
              Dec 7, 2007
              Southeast NE
              Local Time:
              3:39 AM
              The U bolt nuts are a severe locknut. After you get 2 or 3 nuts off you will just go buy new U bolts. AMK has the correct flattened U bolts and those tall lock nuts.
              • Agree Agree x 1
              • lemondana
                lemondana BlackDart
                395
                198
                Dec 7, 2007
                Southeast NE
                Local Time:
                3:39 AM
                Again, AMK has the correct flattened crosshatch bolts in 2 different lengths and the correct tall lock nuts. AMK has a big paper catalog for like $20.00 or $25.00. Get online, order the bolts and nuts and one of their catalogs, It has all of the neat OE bolts and nuts and other assorted for GM, Ford, and Mopar.. It is well worth the money!
              • RustyRatRod
                60,008
                31141
                Jun 7, 2010
                Georgia
                Local Time:
                5:39 AM
                There you go. Even though they are supposed to be one time use, I agree with you. As long as they break loose easily, I'll reuse them too. I coat the threads with RTV when I go back. They won't rust up then.
                • Like Like x 1
                • RustyRatRod
                  60,008
                  31141
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  5:39 AM
                  There's really no "correct" on this. I've torn down a LOT of cars and seen both types of U bolts on the same model.
                  I would be curious to see what @Oldmanmopar has seen on this. That guy has parted out a bunch of cars. I'm sure he'd have some good input.
                • billccm
                  121
                  88
                  May 13, 2018
                  Tucson
                  Local Time:
                  2:39 AM
                • fklskv
                  fklskv Well-Known Member
                  1,111
                  584
                  Aug 14, 2011
                  Lackawanna, NY
                  Local Time:
                  5:39 AM
                  • Agree Agree x 2
                  • Tooljunkie
                    Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
                    14,186
                    13157
                    Jul 22, 2017
                    Manitoba
                    Local Time:
                    4:39 AM
                    the u-bolts aren't supposed to be tightened so they damage axle tubes. the highest I have seen for late models is like 80 foot-lbs
                    locktite also serves as an anti-seize by sealing the threads to prevent corrosion
                  • Car Nut
                    Car Nut Mopar Master
                    13,330
                    57275
                    Dec 28, 2018
                    Zombieland
                    Local Time:
                    3:39 AM
                    Dang, that’s high, even though the books says 45 ft lbs.
                  • Tooljunkie
                    14,186
                    13157
                    Jul 22, 2017
                    Manitoba
                    Local Time:
                    4:39 AM
                    think the f150's, three leaf pack is what I was referring to.
                    too tight on the A bodies does more harm than good.
                  • Marcohotrod
                    Marcohotrod Well-Known Member
                    2,408
                    616
                    Mar 21, 2015
                    Massachusetts
                    Local Time:
                    5:39 AM
                    Calvert and I like 65 foot pounds. I found dumping the clutch with slicks was better with more than 45
                  • mopowers
                    mopowers Well-Known Member
                    4,685
                    1789
                    Feb 15, 2006
                    West Sacramento, CA
                    Local Time:
                    2:39 AM
                    Liquid Wrench did the best in this guy's test, with acetone/ATF in 2nd. Kroil did the WORST. FYI-
                    Here's part 2. In this one, deep creep (sea foam) did the best, with CRC very close behind.
                    • Like Like x 1
                    • dartfreak75
                      dartfreak75 Restore it, Dont part it! FABO Gold Member
                      7,384
                      5150
                      Aug 10, 2011
                      Virginia
                      Local Time:
                      5:39 AM
                      I dont think iv ever gotten a u bolt off without breaking it off. I like Kroil and pb blaster but I havent bought a can of pb blaster in years kroil is my go to because I get it for free. For ubolts I'd just cut them off i wouldn't waste my free kroil on it lol.
                      • Agree Agree x 3
                      • dartfreak75
                        7,384
                        5150
                        Aug 10, 2011
                        Virginia
                        Local Time:
                        5:39 AM
                        I really like that guy I really enjoy his tests.
                      • TrailBeast
                        TrailBeast AKA Mopars4us on Youtube
                        21,285
                        8750
                        Mar 11, 2011
                        Arizona
                        Local Time:
                        2:39 AM
                        This is the ticket right here, no matter what lube you use.
                        I use a drill with about a 3 inch round wire brush to clean the threads before removing the nuts.
                        Note that I just did three cars of U bolts and they all came off easy with cleaned threads.
                        Didn't break or trash threads on any of them.
                        • Like Like x 1
                        • RustyRatRod
                          60,008
                          31141
                          Jun 7, 2010
                          Georgia
                          Local Time:
                          5:39 AM
                          In that video above, he is using Fluid Film in the wrong application, that's why it does not work well. It's not made for use as a penetrating oil, even though it says that as one of the uses on the label. It's best use is for coating parts for storage so they will not rust. For that, it is badass. I like that guy's tests, too. Look how well the Sea Foam does. I've been tellin yall that stuff is the shizzle.
                          • Agree Agree x 3
                          • Texas Red
                            Texas Red Old Flunky FABO Gold Member
                            25
                            20
                            Mar 25, 2020
                            Lake Corpus Christi
                            Local Time:
                            4:39 AM
                            Acetone & tranny fluid gets my vote...What Brian6pack said & others....It works very well. And yes New U Bolts. Cheap insurance
                            • Agree Agree x 1
                            • Tooljunkie
                              14,186
                              13157
                              Jul 22, 2017
                              Manitoba
                              Local Time:
                              4:39 AM
                              Fluid film if you arent in a hurry.
                              But a little heat improves capillary action greatly. I always keep a can around.
